Question about XO Vision XO9013 Car DVD Player
Detecting wire for back a car - XO Vision XO9013 Car DVD Player
Check engine light stays on
code p0460 refers to fuel tank level sensor--circuit malfunction===causes ---wiring---fuel tank level sensor---ECM. However in the Volvo section there is a p1446 code that refers to evaporative emission (EVAP) leak detection pump---signal malfunction====causes wiring--poor connection---EVAP leak detection pump.
Go back to who read the codes and ensure that the right code was told to you.l
Dec 22, 2013 | Volvo S40 Cars & Trucks
Got in car this morning and radio was blinking protect
Hi.
Protect mode is a special condition that kicks in when an internal fault has been detected. In protect mode all the unit function are disabled to prevent the stereo getting more damage in consequence of the fault. The state is a forced standby condition that starts when a wrong voltage or a short is detected.
Try disconnecting the battery terminal, pulling the radio out of the dash and checking the wiring at the back of the stereo. Most of the time protect mode is triggered by a wiring contact. If possible check also speaker wiring. A contact in wiring to speakers will trigger protect.
Regards.
Ginko
Sep 14, 2011 | Kenwood KDC-MP235 CD Player
In protect mode
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage, or a bare wire touching the body of the car
Mar 17, 2010 | Kenwood KDC-MP242
When switch on power, the protect breaker shuts it down
Feb 27, 2010 | Pyramid - PS52KX 40 Amp Power Supply Car...
Hi, I'm installing a DVD Player PDBT30U and I have a doubt!
connect the brake wire to the black(negative) dat way you could play dvd's while you drive
Dec 26, 2009 | Car Audio & Video
Kenwood kdc-bt742u flashing protect and no sound
Dec 17, 2009 | Kenwood KDC-BT742U
What is the diagnostic codes P 0700 P1684 p0442 p0455 p0456 on a 2001 dodge Caravan with a 3 3"
P0700: EATX Controller DTC present
P1684: Battery was desconnected
P0442: EVAP leak monitor medium (.040). Leak detected.
P0455:
EVAP leak monitor large. Leak detected.
P0456: EVAP leak monitor small (.020). Leak detected.
I suggest check the lines and flow it down to the ldp (leak detection pump) that is just behind the steering gear under the van It has a wire connector and 2 large EVAP hoses. look for any split or crack then follow the lines back to the tank. Even a small crack is a leak.
Hope helped with this. Remember rated this help. Good luck.
Nov 24, 2009 | Dodge Caravan Cars & Trucks
Screen shows PROTECT and i can't hear nothing and do nothing
The receiver is in protect mode either due to heat or crossed speaker wires. Heat would take a while to shut off and a while to turn back on. The speaker wire short would be detected immediately.
Mar 07, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
XO Vision XO9013 Car DVD Player Logo
22 people viewed this question
Top XO Vision Car Audio & Video Experts
mega_mind
Andy
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
