Question about Lasko 3300 Wind Machine Fan
Balloon string caught in ceiling fan motor. will not run now
How toget a fan working again
The string is probably wrapped up on something. Take it out.
Aug 31, 2014 | Heating & Cooling
Can a balloon string burn up a ceiling fan motor
Yes, if the string slows rotation of the fan so it overheats.
Jul 11, 2014 | Vornado FA1-0003-13 Table Fan
Bionaire BF1209R motor possibly burned out from a string caught in blades What are some solutions besides getting a new fan
The motor has a fuse buried in the windings near where the wires connect to the motor. Sometimes, if you're careful, you can expose the wires and jump around the fuse. Otherwise a new motor in in order.
Feb 23, 2014 | Dryers
A string got caught in the blades and now it won't start up.
if the string was caught in the blades for some time the motor kept running and could not move the blades the motor just burnt up from the stress to the motor.
Aug 02, 2011 | Vornado FA1-0003-13 Table Fan
A balloon string got stuck behind the blades of my Lasko three speed stand up fan while it was running. When i pulled the string out the fan never came back on. What needs to be done to get it working...
remove front of fan sheild, you should be able to see a few screws holding sheild on. remove fan blade then fix it. most blades just pull off of motor shaft. good-day!
Jul 11, 2011 | Heating & Cooling
I understand that the black and blue wire can be connected to the black wire in my ceiling. ok fair enough. However, in my new bedroom, there is 2 switches on the wall that apparently control two black...
A ceiling fan requires a neutral wire (white), a ground wire (green), a hot wire for the fan (black), and on fans with light kits a hot wire for the lights (blue). These examples will assume that a lighting kit is going to be used, but if it is not terminations to the blue wire are not required and the circuit is greatly simplified The ceiling fan and light can also be wired through switches. When a single switch is used to connect to the ceiling fan and light the ceiling fan (black) and light (blue) would both be connected to the switched black wire. In this configuration turning the switch on would power both the light and ceiling fan. In order to turn just one off, the pull strings would have to be used. The problem with this approach, is that when the pull strings have been used to turn the light or ceiling fan off, turning the switch back on will not work until the pull string is pulled again .
The ceiling fan and light can also be wired through two switches. This would generally be two separate switches, one for the fan and one for the light. This would generally be a 3 conductor w/ground coming from the switch box. The ceiling fan (black) wire would connect to the switched black wire from the ceiling fan switch, the light wire (blue) would connect to the switched red wire from the light switch and the neutral (white) and ground (bare) would connect to the their associated wires..
Jul 07, 2011 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Remote lightswitch won't work.
This may be obvious but you may need to turn the light on with the string and leave it on. Then the remote should work. Sorry if this doens't work or is too simple.
Feb 28, 2010 | Oasis Hunter 54' Ceiling Fan
String caught in the motor
OK - first things first. There's no way a shoe string, or anything else, can possibly get caught in the motor. If the string isn't wrapped around the brush roll it's probably gone through in to the bag. Please reply, describing the symptoms you've observed in as much detail as possible, then maybe we can figure out just what's happened.
Jan 22, 2010 | Dirt Devil M085530 Featherlite Bagged...
MY CHILD'S BALLON STRING GOT CAUGHT IN MY ALOHA FAN, I TOOK THE STRING OUT BUT NOW IT WILL NOT COME ON, HELP PLEASE!
it probably slowed or stalled the motor down so far that if its variable speed it burned out the speed control triac in the speed control,you need to access the speed control board and find the problem,otherwise if the motor isn't harmed too bad,direct wire(bypass) speed control and run on high
Oct 11, 2009 | Aloha Housewares Breeze 29" Tower Fan
Ceiling fan won't blow any air
if its turning its either sucking or blowing air. There is a switch or a pull cord to reverse it. prove it to yourself with something light like a feather or piece of paper or balloon.
Aug 16, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Lasko 3300 Wind Machine Fan Logo
428 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
