Question about QSC MX1500A 2-Channel Amplifier
Older QSC amp has a surge in only one channel
The amp will have a spike of volume with distortion on one channel. I havent paid attention to see if it is always the same channel.
3 Suggested Answers
  • 4234 Answers
SOURCE: i have qsc amp model noisa500it 2nd channel is not
It is likely that additional components were damaged when the output transistors (2SC5200, 2SA1943) were shorted. Check the driver transistors which preceed the outputs in the circuit as well as resistors in the area. Also, there should be a bias transistor mounted on the heat sink that needs to be checked as well.
Keep us posted,
Dan
Posted on Mar 02, 2010
  • 166 Answers
SOURCE: qsc mx 2000a left channel go into protek mode
Does it do it with nothing connected to the inputs and outputs? If yes, something internal.. anything loose in there (is it moved alot and something could have fallen inside of it)
Posted on Mar 28, 2010
Turned volume up all three amps shout down at one time
That sounds like it could be a power supply issue to the main amp board. Possibly a voltage control regulator function issue?
Feb 12, 2014 | QSC MX1500A 2-Channel Amplifier
Not putting out sound fan on light on
A common issue with the QSC RMX series amp is faulty volume pots, so i would recommend go this way first of all, let me know a bit more to improve help.
Feb 04, 2013 | QSC Audio Products QSC RMX 850 RMX850...
How do I bridge my QSC GX 3 amp to run one speaker cabinet?
For QSC amps the GX series are not bridgeable. You will have to run one speaker to each channel.
Mar 22, 2011 | QSC GX3 Amplifier
One channel's red led is always on and no sound
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/QSC-GX3-Amps-manual/id/23107ag606/t/2/
See page 7.
"CLIP: red, to the left of each Gain control.
Normal indication: illuminates whenever the amplifier is driven beyond full power. The LED's brightness indicates the amount of distortion. Distortion that causes only brief flashing may not be audible.
During muting, the indicator fully illuminates. This occurs during normal "On-Off
Mar 17, 2011 | QSC GX3 Amplifier
My amps stays in the clip mode where as the light on the two channel stays red
http://www.retrevo.com/support/QSC-RMX-4050HD-Amps-manual/id/23107ci658/t/2/
Page 7...
During muting, the indicator fully illuminates. This occurs during normal "On-Off" muting.
Abnormal indication:
•Bright red illumination while the amp is being used indicates either thermal muting or a shorted output.
•If the amplifier overheats, the fan will run at full speed, and operation should resume within one minute. Allow the fan to run, and make sure the amplifier ventilation is adequate.
•A shorted or overloaded output circuit will cause excessive Clip flashing and possible overheating.
•If distortion is audible without a Clip indication, the problem is either before or after the amplifier. Check for damaged speakers or overloaded signal source. The amplifier Gain control should be in the upper half of its range to prevent input overload.
Jan 29, 2011 | QSC RMX 4050HD 2Channel Amplifier
The volume goes up by itself - SABA M5115GT
This is due to the signal reception. Some channels are broad casted with strong signal strength. Therefor you will find the audio is louder than other channels. Also, if there is voltage fluctuation/surges/spikes that is also responsible for suddenly increasing the volume. Best is to put a voltage stablizer
Jan 22, 2010 | Televison & Video
QSC ISA 280 Stereo Power Amp stopped working
This is a very precise questions as QSC amp are pretty rare and high end electronics equipment. There is no way getting an answer other than getting the amp at a sound shop for repair, wich might go for a visit at QSC anyway. From a sound shop repairman...
Sep 07, 2009 | QSC ISA 300Ti Amplifier
CS-800 buzz in channel a
First a couple of questions:
1) Is the level of buzz controlled by the volume control? Based upon your initial post I would think yes.
2)When you say you want to use the other amp as a regular amp, do you mean to drive a single speaker or more?
Dan
Feb 06, 2009 | QSC MX1500A 2-Channel Amplifier
QSC 2450 Power amplifier
i have a pyle pro 1000 watt max 2 channel mono and 2 channel stereo and when i get that thing loud the little red light cums on basically what i mean is that the amp on channel one is cooked i myself i wouldn't even use it y cause more damage
Apr 03, 2008 | QSC RMX-2450 Car Audio Amplifier
Loud distortion on Front Channels
Well, the nice thing about the newer amps is that the actual amp circuitry is all contained in a module and you don't have to do much troubleshooting. Just replace the module for that pair of channels. Bad news of course is the modules can be pricey. Should say right on it the part number, order it from mcminone.com or whoever, solder it in, use new conductive grease (many times I think these modules fail because the grease gets old, the module overheats and toasts) and you should be fixya'd
Jan 12, 2008 | Marantz SR-5200 Receiver
Open Questions:
See all QSC MX1500A 2-Channel Amplifier Questions
QSC MX1500A 2-Channel Amplifier Logo
35 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
