Question about Miele CVA4070 Coffee Maker
Fault 94 on Miele built in coffee maker - Miele CVA4070 Coffee Maker
4 Suggested Answers
SOURCE: miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Posted on Apr 09, 2009
gwshaw71
  • 83 Answers
SOURCE: need a new water container
i have a cva 615 im parting out
Posted on Dec 04, 2010
  • 40 Answers
SOURCE: While cleaning Miele built in coffee maker, Fault
Insufficient water intake. Check that the water tank is installed correctly. Check hoses and connections. Check water tank valve.
Posted on Feb 28, 2011
Miele cva4070 coffee maker showing fault76
Fault 76 is caused by there being too much coffee to compress . Assuming there is not a fault with brew unit or brew unit drive, then try to use less coffee (see menu settings) or grind the coffee to a finer level (see manual). regards
Jun 16, 2014 | Miele CVA4070 Coffee Maker
Miele CVA5065 coffee machine has fault 77
I am not familiar with a CVA 5065 - but most of the other Miele coffee systems fault 77 is the ceramic valve initialization or the switch (S51) associated with it.
Apr 20, 2014 | Miele Coffee Makers & Espresso Machines
Want to clean the grinder part of my built in miele coffee maker.
Very Carefully with the power plug pulled out of the wall.
If you do not have the manual, go on line and have customer service send you a detailed instruction manual or have a technician take you through the process.
Mar 25, 2014 | Miele CVA4070 Coffee Maker
While cleaning Miele built in coffee maker, Fault 17 appeared. What does this mean?
Feb 27, 2011 | Miele CVA2660 Stainless Steel Coffee Maker
F17 fault
Try posting your question in the oven section as opposed to the coffee maker section. You might get more responses
Feb 06, 2010 | Miele CVA4070 Coffee Maker
Says in the display Fault 10 and Fault 17. CVA 4060 built-in coffee machine Miele
I just switched machine off for a few hours and when started, it was OK
Sep 07, 2009 | Coffee Makers & Espresso Machines
Miele built-in coffee machine. I've set the wrong language. How do I reset it back to English? Please help.
Language setting is on page 19 of the owners manual =>
http://www.miele.com/manuals_pdf/Residential/Coffee_System/CVA4070_us.pdf
Please leave feedback Thank you.
Nov 04, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4070 Coffee Maker Logo
199 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
