Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
My road king beeps 10 times but wont move - Pride Go-Go Ultra X 3-Wheel Travel Scooter
Harley troubleshooting
Engine Runs but Misfires
1. Fouled or improperly gapped spark plugs.
2. Damaged spark plug cables.
3. Incorrect ignition timing.
4. Defective ignition components.
5. An obstructed fuel line or fuel shutoff valve
(carbureted models).
6. Obstructed fuel filter.
7. Clogged carburetor jets.
8. Malfunctioning fuel pump (fuel injected models).
9. Loose battery connection.
10. Wiring or connector damage.
11. Water or other contaminates in the fuel.
12. Weak or damaged valve springs.
13. Incorrect camshaft/valve timing.
14. A damaged valve(s).
Jul 11, 2014 | 2002 Harley Davidson FLHRCI Road King...
My 2003 road King Wont start
Battery is prob weak.. Try jumping it with car, or battery charger
Apr 13, 2013 | 2003 Harley Davidson FLHR Road king
2003 harley road king inner primary torque specs
Hi Anonymous, and your torque specs are:
1. 1/4" bolts 10 ft lbs.
2. 5/16" bolts 20 ft lbs.
3. 3/8" bolts 35 ft lbs.
4. 7/16" bolts 55 ft lbs.
5. 1/2" bolts 75 ft lbs.
Have nice day.
Apr 11, 2013 | 2008 Harley Davidson FLHR Road king
How much pis in front forks hd flhr road king
15 psi is the Factory recommended pressure.
Try it. If it feels too spongy pump it up to 18-20. If you need more give it a bit more but never go over 25 psi!
If it feels to harsh drop the pressure to about 10 psi.
Worth checking your fork oil too. You really need clean new oil every 10,000 kilometres (6,000 miles).
Feb 27, 2013 | 2000 Harley Davidson FLHR-FLHRI Road king
Cannot change security code on 2007 harley davidson road king
TURN IGN ON OFF ON OFF ON
PUSH LEFT TURN SWITCH 3 TIMES
PUSH RIGHT TURN SWITCH ONCE, ODOMETER WILL SHOW 5 SPACES
PUSH LEFT TURN TO PUT IN THE # YOU WANT, THEN PUSH RIGHT TURN ONCE TO ENTER IT, SAME PROCEDURE FOR THE LAST FOUR DIGETS. WHEN ALL 5 DIGETS ARE THERE TURN OFF IGN SWITCH THAT WILL SAVE IT IN MEMORY, ALSO WRITE THE CODE DOWN SO YOU WONT FORGET IT
Jan 13, 2013 | 2008 Harley Davidson FLHR Road king
How much air should be in a 2008 road king classic air shock
SOLO RIDER
Up to 150 lbs = 0 psi
150 - 200 lbs = 0-10 psi
200 -250 lbs = 5-15 psi
RIDER WITH PASSENGER
Up to 150 lbs = 10-15 psi
Up to 200 lbs = 20-25 psi
MAXIMUM = 20-35 psi
Aug 28, 2012 | 2008 Harley Davidson FLHRC Road King...
I cannot disable the alarm on my 2003 HD Road King. I have the key fob but don't have the owner's manual.
service/and transport mode, 1 .with ING off disarm with fob. 2.turn on ING.3. press and hold key fob untill beep.4. turn ING off.5. press and hold till beep.
Jul 25, 2010 | 2003 Harley Davidson FLHRCI Road King...
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
