Question about Konica Minolta magicolor 2300DL Laser Printer
Fatal Error 17H - toner cartridges will not advance
I went to Konica Minolta's website to look up the 17H error code, and it's telling me to take out and reinstall all the toners. Problem is, two toner colors are showing (black and yellow), and I don't know how to advance them to get any of them out. There's a grinding noise before I see the error code, and the answer guide says that could be the gears on one of the cartridges that doesn't want to move. I removed the waste toner bottle and the drum, but couldn't get any farther than that. Please help!
  • Anonymous Mar 16, 2014
    fatal error code 17H
  • Konica Minolta Master
  • 705 Answers
Open the front door and remove the toner bottle.
Look near the colour toner carts and you will see a small round hole. Jam a screwdriver in that hole and the carousel will rotate freely. Move the carousel round and remove each toner one at a time.
Posted on Oct 13, 2007
Inky said to Open the front door and remove the toner bottle.
I did and removed the cartridges and tried moving the gears on the cartridges. The blue one did not rotate. I forced it put all back in and now it's working fine. Hope this helps!
Posted on May 19, 2010
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
I have a FATAL ERROR CODE: 17H on my printer. What do I do?
It has to do with the toner. Please follow these directions: (from Minolta support website)
http://onyxweb.mykonicaminolta.com/newKB/KBDocument.aspx?id=TAUS0900423EN01&ptid=
Dec 02, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Fatal Error 17H
Hi
Thanks for using FixYa. Error 17H means rack rotation failure. While replacing toners, one of them might not be sitting right and due to this cause, the cartridge is stalling the rotation of the rack. You need to remove all of the toners installed by selecting the properties of the printer. After that select "install toner" and reinstall all of them. Check for any physical damage on anything around the toner rack or a small piece of paper jammed in the right hand side of the toner rack.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Jul 23, 2009 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17h
17H is the Rack Rotation error. If your toners are not rotating correctly, or if you have the wrong type (IE 2400 series toners in a 2500 series printer) you will get this error.
Feb 18, 2009 | Konica Minolta Magicolor 2530 DL Laser...
I have a Konica/Minolta 2490 copier that has a service code 17H what is this
17H is an error for the toner , either they are not in all of the way or the latch is not closed....to fix it simply take out the toner and put them back in making sure the latch is closed all the way :-)
Oct 03, 2008 | Minolta Office Equipment & Supplies
Where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17H
Try going through each toner cartridge again. The error is linked to incorrect rotation usually caused by badly seated toner cartridges.
Chris
Dec 06, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Errors
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
Service call Message
Hi. A 17H error indicates that there is a toner rack rotation failure. There is a good chance that at least on of the toners is not seated right and that is keeping the rack from rotating right. If you can select "remove toner" on the display that is on your printer, remove all of the toners, then select "install toner" and reinstall all of them. Also, you will want to check for any physical damage or anything that may be jamming up the toner rack. There could possible be a piece of paper jammed in the right side of the rack. Hope this helps. Good luck.
Jun 30, 2007 | Konica Minolta magicolor 2500W Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
3,309 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
