Question about Hotpoint Kitchen Ranges
Hotpoint ew74k fan not working when door closed
Does anyone know how to by-pass the automatic timer on my hotpoint ew74k main oven??
Yes it is only 2 wires . Do you have picture of set up or are you near birmingham? David "The Famous Forry"
Oct 15, 2017 | Hotpoint Ovens
The main fan assisted oven on a Hotpoint BD35 double oven stopped working so I replaced the element, thinking that would be the obvious answer. Unfortunately it is still not working and I notice that the...
Is there a black pole sticking out that goes in when you close the door, my Hotpoint freestanding cooker has it on the right hand side, once this is pressed in the fan and heat starts, i had to replace it on my cooker as it went faulty and stopped things working (all I had was the main oven light on, these are usually like a little black box that are situated on the side of the oven just behind the main metal panel on the outside and will normally have 2 pull off spade connectors connected to it.
i don't have the same model as you but hopefully this mig help you.
Oct 22, 2017 | Hotpoint DY46 Style Line Stainless Steel...
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
Freezer fan not coming on after clearing ice problem should it come on right away?>
There is a switch that refrigerator door squeeze on when closed. With the door open locate this switch and press it. If the fan comes on, there is nothing wrong with the fan that is how it is suppose to work. If it does not come on then you would have to gain access to the fan and test for voltage at its terminal. If there is voltage then replace the fan. If no voltage then check for broken wires
May 23, 2009 | Hotpoint FFS70 Bottom Freezer Refrigerator
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Kitchen Ranges Logo
15 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
