Question about Saniflo Sanicompact 48 Toilet With Pump, White
Sanicompact 48 nt flushing properly - Saniflo Sanicompact 48 Toilet With Pump, White
How do I wire a 2005 sanicompact?
Use the power cable that came attached to the motor to wire to a fused spur.
Jan 10, 2015 | Saniflo SaniCompact-48 SaniCompact One...
Toilet wont flush
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
Masticator toilet blocked with hanging toilet freshener
It will dissolve however it will take many days you can't wait so you need to go rent or buy or borrow small rooter route to get it out. It's not a bad fix so don't let someone tell you different. You can fix your self. Good luck.
Sep 16, 2012 | Saniflo SaniCompact-48 SaniCompact One...
SaniCompact48 waste water comes up into shower tray when flushing
Got a blockage in your out pipe, could be a rag or a big tur. You need to snake out the main drain going out of your house.
Apr 09, 2012 | Saniflo SaniCompact-48 SaniCompact One...
Sanicompact motor operates continuously but bowl doesn't clear. Have emptied bowl manually and poured Saniflo cleaner in.
This problem occurs when the flush button is damp after cleaning the whole toilet with a shower. Solution: Wait till it dries up 2) if you have installed a main switch put it on and at the same time press the flush button.
Dec 26, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
Macerator blade not turning when fushed but motor running
this is a common problem mainly due to paper being put in them the key that holds the blade in position has become disenged and needs to be replaced
Nov 15, 2009 | Saniflo SaniCompact-48 SaniCompact One...
Replacing Sanicompact toilet seat
I have asked around they take a normal seat on most us models
Feb 03, 2009 | Saniflo 005 Toilet Tank White
Saniflo Sanicompact 48 Toilet With Pump, White Logo
61 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
