Question about Arris Sb6141 Surfboard Cable Modem Sb 6141 Docsis 3.0
Power led stays amber - Arris Sb6141 Surfboard Cable Modem Sb 6141 Docsis 3.0
Here's my problem, I have a belkin n300 extender, ok it worked for about a week or so and one day I lost connection, when I looked it is solid blue, even after I press reset or wps, it stays blue, I don't...
Blue?
the n300 colors.....
4 LED Descriptions
Router Link LED
This LED indicates the connection between the extender and the router or access point.
Solid green
. Best connection.
Solid ambe
r. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Device Link LED
This LED indicates the connection between the extender and a computer or mobile device.
Solid green
. Best connection.
Solid amber
. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Power LED
Solid amber
. The extender is booting.
Solid green
. The extender is powered on.
Off
. The extender is powered off.
WPS LED
Solid green
. WiFi security is enabled (WPA or WPA2).
Blinking green
. A WPS connection is being established.
Off
. WiFi security is not enabled.
Note:
If the Router Link LED or Device Link LED is amber or red, Find the Best Location
Mar 07, 2018 | Belkin Computers & Internet
Amber light on then a while turns green but wont boot
1) Switch the system on. Can you tell me if the power button is flashing amber or a solid amber? Please also tell me if you notice any diagnostics LEDs staying lit - these are labelled 1,2,3 and 4 and are near the front headphone sockets
2) Please remove all peripherals at the back of the system and switch the system on. Does this affect the power button LED or diagnostic LEDs
3) Have you added any components to the system e.g. video cards, sound cards etc...
4) Please open the system and remove the following components:
a) Power and data cables from hard drives and optical drivesb) Any PCI/PCI-Express expansion cardsc) All memory from the systemd) The system fan
5) With the above removed, please reconnect the power cord to the back of the system and switch the system on. Please make a note of what happens with the power button LED and the diagnostic LEDs
6) If there are no changes to the power button LED or diagnostic LEDs, please remove the power cord from the back of the system and remove the following components:
a) I/O panel cableb) CMOS battery
7) With the I/O panel cable and CMOS battery removed, please connect the power cord to the back of the system. The system should automatically try to switch on. Do you hear any beeps from the system? If so, can you tell us exactly what you hear?
If you need any assistance with removing these components, please see the User Manual here: http://support.euro.dell.com/support/edocs/systems/op380/en/index.htm
Please keep us updated on how you get on!
May 21, 2014 | Dell OptiPlex 380 MT Desktop Computer...
Cooper 9534SG-K master dimmer amber LED goes out when lightsbturned off
Any switch with a light in it needs power to the switch along with neutral
May 07, 2014 | Cooper Wiring Devices Aspire Smart Dimmer...
Power led light is a steady orange but pc will not power up
If the power light is blinking amber, the computer is receiving electrical
power, a device might be malfunctioning or incorrectly installed.
- Remove and then reinstall the memory modules (see "Memory" on
page 112).
- Remove and then reinstall any cards (see "Cards" on page 116).
- Remove and then reinstall the graphics card, if applicable (see "Cards"
on page 116).
• If the power light is steady amber, there may be a power problem or an
internal device malfunction.
- Ensure that all power cables are securely connected to the system
board (see "System Board Components" on page 107).
- Ensure that the main power cable and front panel cable are securely
connected to the system board (see "System Board Components"
Copy and paste this link to your internet browser for your computer's manual.
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_inspiron_desktop/inspiron-531s_owner%27s%20manual_en-us.pdf
You can also go to support.dell.com
Jan 08, 2013 | Dell Dimension 4600 PC Desktop
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Power button stay amber, dont finish booting
Generally, this is an indication of a motherboard failure. Remove any items connected externally and and expansion cards intenally and see if the Power LED indication changes. if not changes, then replace the motherboard
Mar 31, 2009 | Dell Dimension 3100 PC Desktop
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Yello power light, dell
1st remove all PCI cards, see if anything changes.  If no change\:
If the power LED is solid AMBER, replace the motherboard
If Flashing AMber, replace the power supply
Sep 08, 2008 | Dell OptiPlex GX260 PC Desktop
Vizio in stand by (amber lights) mode on monitor
Does the remote have one power button for on/off .... or, does it have separate buttons ?
Jan 13, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Arris Sb6141 Surfboard Cable Modem Sb 6141 Docsis 3.0 Logo
18 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
