Question about Amana AMV1162 Microwave Oven
Frigidaire model fmv145bc1 microwave will not heat everything else works, fan sounds a little different sfter about three seconds of being on
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
I started up oven and it made two popping sounds. now fan lights turntable still work but not heating also sounds different then before.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 30, 2011 | Frigidaire PLMV169DC Microwave Oven
Frigidaire microwave not heating
Basic Microwave Oven TroubleshootingTips
heatman101=--=-=
May 19, 2010 | Frigidaire FMT148G1 Microwave Oven
I have a FMV145BC1 microwave oven, 5 yr old, everything works but food does not get hot!
Does the food get warm at all? My suspicion is you have a bad door switch. Do you open the door while the machine is running, ever? If yes, that is not good for the little contacts on the door safety interlock micro switches. I learned this by burning mine up. The switches are less than $ at a radio supply place and typically, you can change them yourself.
Unplug the machine. Remove the cover and you will find the interlock switches on the handle side of the door, probably on the right hand side. DO NOT TOUCH THE SILVER THING AT THE BACK SIDE OF THE MACHINE - IT IS POTENTIALLY LETHAL EVEN WHEN UNPLUGGED. If you have a volt ohm meter, you can test these switches for open and closed. If they read open when the door is closed, they (or it) is probably bad.
Sep 14, 2009 | Frigidaire FMV145K Microwave Oven
Sound different and does not heat with full force
the fan is not working. it is necessary for the fan to run to cool the magnetron tube. do not use till repaired as prolonged lack of cooling will destroy tube
Aug 26, 2009 | Frigidaire FMV157GM Microwave Oven
FMV145BC1 - Frigidare Microwave will not heat
heatman101
dhdgh
Aug 14, 2009 | Frigidaire FMV145K Microwave Oven
Does everything but heat food.
Sounds like the magnatron tube or it's fuse.
Aug 11, 2009 | Kenmore 80809 Microwave Oven
Amana AMV1162 Microwave Oven Logo
20 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
