Question about Electrolux Vacuums
Electrolux nimble vacuum wand does not suck - Electrolux Vacuums
  • 833 Answers
SOURCE: toy stuck in hose
Generally, this is a job for patience!  First, remove the hose from the unit.  Try a broom handle to push the toy out...you will not damage the hose.  If that doesn't work, you can use a piece of stiff wire fed through the hose with hooked end.  An electrician's fishtape...a snake...is often useful.
Posted on Nov 27, 2008
  • 4 Answers
SOURCE: electrolux oxygen vacuum
WARNING WARNING Danger danger Will Robinson! The power head "wand" and the hose from the body of the vacuum have shorts in them. While my wife was using this machine.. she started smelling plastic.. seeing whitish smoke and then sparks... The pin connector arc'd through the plastic... Some research on Google found that this has been a large problem for Electrolux, when i tried to call the factory.. robots.... no solution. Then I contacted a distributor and they informed me that it was not really that big of a problem. Only later to say, that they had replaced ALOT of them. My unit was past its warranty period so I just hardwired it. (now the unit is only two pieces, body and hose w/wand.)
Posted on Nov 07, 2009
jse2005
  • 103 Answers
SOURCE: electrolux vacuum cleaner 1500W motor diagram
if motor is turning than it's not the motor......check for other more than likely faults such as.......restricted or kinked hoses......obstructed hoses,......clogged vents both intake and output sides.......clogged heppa filters on the output side...after the motor if it has one......restricted or obstructed intake air vents where the motor sucks air in........clogged bags if it uses bags.....in any case, you have something either blocking or restricting the suction side or something restricting the air output side.........if all is well and you see no blockages, then and only then should you suspect the motor.
Posted on Nov 27, 2009
SOURCE: The clip that holds the EL5 powerhead to the wand has broken (again). How does one fix this?
i found this part online- search for part # via an exploded parts diagram of your specific unit (via google)
i ordered 5 of them because it always breaks or pops out.
this is a nice machine with crappy parts.
sorry :(
Posted on Nov 01, 2010
rickyrt441
  • 4399 Answers
SOURCE: My electrolux twinclean cyclone vacuum cleaner
Have you made sure the bottom of the cleaner is clear and not clogged?
Posted on Mar 05, 2011
Electrolux EL/8602a. How can I replace power cord?
take lower body covers off to access end of power cord , un clip the 2 wires remembering the proper routing and colors, hook up your new cord and re assemble
below is a link to new power cord
Electrolux Nimble EL8602 OEM electric power cord replacement part cable...
Jan 30, 2016 | Electrolux Vacuums
How to replace el8602a power cord
Electrolux Vacuum Cleaner EL 8602A How to replace the ...
www.manualsonline.com/.../vacuum.../how-to-replace-the-power-cord-o...
Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
Rewiring the Power Cord for the Electrolux Model G ...
? 4:27
https://www.youtube.com/watch?v=4uqNa7mVBO8
Jan 30, 2012 - Uploaded by Jayson1940D14
Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
Electrolux Nimble Upright Vacuum, EL8602A - YouTube
? 3:49
https://www.youtube.com/watch?v=-anwdD4fK-o
Nov 11, 2014 - Uploaded by Michael Callender
Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
Jan 30, 2016 | Vacuums
The wand on this vacuum has suction, but the base unit does not. I have checked all filters, the hose and connections for blockage, etc. The brush is rolling.
some vac's have a small slide that stops te wand suction when the wand sucks the other parts gets none
May 11, 2015 | Vacuums
How do you get wand to suck
Hahaha, , maybe you should ..... sorry... that's just funny. Take it to your local vac shop.
Oct 29, 2014 | Electrolux Vacuums
How to repair roller on Vacuum cleaner
it migh be the belt.stretched and hardened from heat replace and try again
Feb 02, 2012 | Electrolux Vacuums
I need a price for a wand for my electrolux ambassador 2100 vacuum cleaner
This same wand is used on all older canister models since 1974 until about 1995.
Metal wand, about $24.
Upper wand assembly, about $34.
Parts should be available at any Aerus shop.
Of course, you can try to find used ones, often with complete vacuum, at second hand stores, pawn shops, yard sales, estate sales, etc.
Sep 29, 2009 | Electrolux Vacuums
Electrolux Ambassador stainless lower wand
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113654&thid=638738
Posted by Cuyler on Jun 01, 2008
I am trying to locate a stainless lower wand for an Electrolux Ambassador model 1623. The search has proven fruitless so far. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. A couple of thought came to mind that you can try. Look in the yellow pages for your local vacuum dealer to see if they carry it to contact your Electrolux factory @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 01, 2008 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
54 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
