Question about Kitchen Ranges
Kenmore Elite(M# 790.96599601) smooth top inner element not working
Inner element will no longer heat up. the two other rings work fine
4 Suggested Answers
SOURCE: Kenmore Elite 790 Range
I can't believe I found this today. Today, my Elite 790 inner coil also stopped working! A little too coincidental.
When I turn on the burner, I can hear like a relay click on, but it does not heat. The middle and outer burners are fine.
Posted on Dec 21, 2007
  • 311 Answers
SOURCE: The inner right front element
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore elite range 790 and the front
It appears your element or clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore c970-440935. Why does one element overheat?
Kenmore Elite C970 440935 Replace heating element range
www.fixya.com > ... > Ovens > Kenmore > Kenmore Elite C970 440935
Kenmore Elite C970 440935, replace heating element range related issues. Get free help, solutions & advice from top Kenmore experts. ... Kenmore 40494 / 40495 / 40499 Electric Single Oven. 793 Questions ..
Aug 05, 2015 | Kitchen Ranges
Kenmore 790.9641* free-standing electric range: The "single" (inner) part of the dual radiant element is not working. When the knob is turned to the single side, the ELEMENT ON indicator lights, but
The inner ring or center part of the element is burned out. You will need to replace the entire element, as it is not possible to replace just part of it.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 19, 2014 | Kenmore Kitchen Ranges
Kenmore elite model 665 17263402 The top rack is not cleaning the dishes. The bottom rack is cleaning fine. What is causing this and how can I fix it? Please help.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My Kenmore elite electric dryer will not heat. I
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
Inner burner on duo element does not heat up. Seems dead.
This could be either the element itself or the switch that controls the element. Since the outer ring is working the issue almost always is with the element. The top can come up and the element replaced.
It is a moderate repair, so some technical ability will be required, the use of an ohmmeter is needed to verify the component that has failed. Let me know if you need more information.
May 06, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Apr 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
Nov 28, 2008 | Kenmore Kitchen Ranges
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
Dec 20, 2007 | Kitchen Ranges
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
