Question about Super Tutor Trigonometry (ESDTRIG) for PC
A rectangle is 87 feet by 136 feet. find the lenght of the diagonal and the angles that it makes with side.? answers and solution
51 inches tall and 12 inches wide. What is that in linear ft.
A total of 63 linear inches is 5 ft 3 in, or 5.25 linear ft.
Dec 03, 2015 | Office Equipment & Supplies
How long is 13 cu feet like how many foot is that
One cubic foot is a cube one foot long, one foot high, and one foot wide. How long is 13 cubic feet is is not answerable because it could be any number of lengths depending on the lengths of the other two dimensions.
May 16, 2015 | Office Equipment & Supplies
A rectangle is 5 feet long and 6 feet wide. what is the perimeter of the rectangle?
Hi Jacqueline:
A rectangle has four sides, the lengths of the opposite sides are equal, and the corners are right angles.
The perimeter is the distance around the outside edge, so it would be twice the length plus twice the width.
2 times 5 = 10 feet
2 times 6 = 12 feet
10 plus 12 = 22 feet
What is important is to understand the question.
If you need help with the course, get back to me.
Cheerfuls!
May 13, 2015 | Computers & Internet
Two sides of a parallelogram are 694.50 feet and 418.32 feet respectively; one diagonal is 602.94 feet. what is the length of the other diagonal
The three dimensions you have given are also the three sides of a triangle. the length of the other diagonal is equal to twice the distance from the center point of the 602.94 diagonal to the vertex between the 694.50 and 418.32 legs.
Do your homework.
Feb 02, 2015 | Computers & Internet
A rectangle is 87 feet by 136 feet. find the length of the diagonal and the angles that it makes with the sides.
Length of diagonal =SQRT(136^2+87^2)=161.4465856 ft
One angle = arctan(87/136)=32.60... degrees
Other angle= 90-32.60=57.39 degrees
Sep 10, 2011 | Super Tutor Trigonometry (ESDTRIG) for PC
Need to find the diagonal of a rectangle. Problem is 5' 3 1/2" x 12' 5 1/4". Do I need to convert the fractions to a decimal? I understand to (a)2 x (b)2 = (c)2. The inches with fraction is my problem!...
ra4942 ,
Yes, you would have to convert the fractions into decimal notation, represented as feet.
Example: 5' 3 1/2" is 5.29167'
By the way, the formula (that you know) is "plus", not "times" ....
a^2 plus b^2 = c^2 (the square of the hypotenuse is the SUM of the squares of the two other sides)
Thanks for using FixYa!
-Gort.
Oct 14, 2010 | MathRescue Word Problems Of Algebra Lite
How do i find area of a rectangle that has 1 straight side and the other is a triangle its irregular plz keep it simple / -------------I /-------------I
You shape is a rectangle and a right angled triangle. You need to divide it into the rectangle and the right angled triangle and add the areas.
Area of a rectangle is length * width
Then just add the two together.
Oct 08, 2009 | The Learning Company Achieve! Math &...
Computers & Internet Logo
Top Super Tutor Computers & Internet Experts
ali_zulfikar
ali_zulfikar
k24674
Are you a Super Tutor Computer and Internet Expert? Answer questions, earn points and help others
