Question about John Deere Garden
Fuel pump intermittent problem as mower will shut down after running a short while
4 Suggested Answers
  • 5 Answers
SOURCE: Husqvarna 24 hp mower shuts down after about 5 or 10 min.
I WOULD LOOK FOR AN ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN WITH SPARK TESTER TO SEE IF IT IS FIRING.
Posted on Apr 08, 2009
  • 229 Answers
SOURCE: After the mower gets hot, it shuts down.
my john deere did the same thing i had spark and it did run,but the coil heated up an there was a short in it and it would stop and you wait awhile and it cool down and it would start again,i replaced the coil and the problem was gone.
Posted on Sep 14, 2009
  • 6468 Answers
SOURCE: My 25 horse kohler starts when I put gas in the carb, then shuts off. I have gas from the fuel pump--HELP!
first check for power going to the solenoid on the bottom of the carb its a anti backfire valve if you have power there when the key is cranking and when turned on the solenoid might just be stuck if that works maybe the gas that was left in the carb turn bad
Posted on Apr 12, 2012
Just installed a new fuel pump and filter on my 1994 Taurus. Goes a short distance then shuts off, fan running.
1994 Ford Taurus / Mercury Sable dies intermittently... help ...
www.city-data.com > ... > Brand-specific forums > Ford and Lincoln
Aug 14, 2010 - 10 posts - ‎10 authors This is a safety feature that shuts off the fuel pump if the car takes a ... 1994 FordTaurus 3.0, my car has 46000 miles on the odometer, ... I stop for usually an hour then head out again about 1/2 hour down the road the car dies. More results from www.city-data.com
Sep 12, 2015 | Cars & Trucks
By pass fuel solenoid
are you sure that's not a fuel pump ? unless this thing runs on diesel , im pretty sure that's a fuel pump not a fuel shut off , and no ya cant run without a fuel pump , but I gotta ask do you know the exact cause of the fire ? if theres a possibility that it was the fuel pump overloaded , just hooking a hot wire to it could burn the entire machine down
Jul 07, 2015 | Toro TimeCutter SS5000 zero turn mower
1986 plymouth horizon falls on its face going down the road intermittently. I have tried a distributor pick up and coil. The car has a new weber carb and fuel pump. It also has a complete tune up with fuel...
I'd check the electric going to the fuel pump as well as any other devices. An intermittent short, bad ground wire can stop the fuel pump.
I'd be more specific with the description. "Falls on it's face", is not a good description.
Nov 21, 2013 | Cars & Trucks
Fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
May 15, 2012 | Briggs & Stratton Briggs Stratton...
Huskee 16 hp Tecumseh starts and runs great but
When it shuts down check it for spark. You sound like you may have a weak coil. OR
You might have water in your fuel and it only runs until it hits the water level in the carb. You can try draining your carb *(do this when mower is cold...never drain gas from a hot mower!) and see if the mower runs longer. While you are draining your fuel you can check the float level too. A float that closes too early or that is partially obstructed might only let in enough fuel to run for short periods. Then, your three minutes of sitting is just to let the carb bowl refill. When you remove the carb bowl let the float hang down and note the fuel flow. Is it fast? Or is it just a slow drip? If it seems slow you should work the float up and down a few times to see if the flow improves. If it does improve consider draining all the fuel out and cleaning the gas tank.
Good luck and be careful!
Jul 16, 2010 | Garden
No crank and stall condition when hot
Swap the fuel pump relay with the A/C relay and see if the problem continues. the A/C relay and the fuel pump relay are the same. If it continues, the fuel pump may be getting overheated and will intermittently shut down. The CPS will certainly do something similar but you wouldn't have spark either.
Mar 29, 2010 | 1988 Chevrolet Cavalier Z24
Sep 13, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Engine runs rough and intermittently shuts down
start with tune up... air n fuel filters, spark plugs and wires good place to start... if not fuel pumps like to go out in gm products
Jul 31, 2009 | 1994 Oldsmobile Cutlass Ciera
Mar 22, 2009 | Husqvarna Garden
2001 Taurus engine shuts off while running.
May be a bad fuel pump or fuel pump relay/. Good Luck
Dec 27, 2008 | 2001 Ford Taurus
Garden Logo
20 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
