Question about SanDisk Sansa e250 MP3 Player
The sound when I plug the headphones into the sansa, the left earpiece does not have any sound. I tried different earphones and the same problems still exist. What should I do?
  • 626 Answers
The headset jack on the circuit board is loose. If its less than a year old have it replaced. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Posted on Oct 10, 2007
SOURCE:
Sound works for radio not for music volume is up music is playing no sound from any headphones
Did you try plugging in a different set of headphones? If other headphones work, maybe you need new headphones.
Try playing music from your Sansa through the computer, while it is tethered. If you can do this, it may mean that the audio amplifier part of the Sansa is broken-- Usually this means, 'get another Sansa.'
Also, try gently wiggling the headphone plug to the left and right, while it is plugged in. If you get music on and off, its possible that the headphone connector on your Sansa has a broken connection. This is a VERY difficult problem to fix (without breaking or melting something else inside the case) and also usually means it is time to get another MP3 player.
Nov 07, 2011 | SanDisk Sansa Clip MP3 Player
Left earpiece has no sound.. can that be fixed?
either theirs something that happaned to the wire like it got stretched out and the inside braided wires pulled apart or came disconnected from the piezoelectric elements, or you have blown the side out.
Dec 21, 2009 | Bose in-ear headphones - Black with...
Left side of earphones don't work
I have the same problem as well. you just have to take the headphones out, and not put them in all the way. just put them in partway, wait until you can hear out of both.
Jul 28, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sound to one earphone only unless pressure applied.
try taking a cue tip or something smaller and cleaning out the inside of the earphone port, sometimes dust can cause interference with the headphones
Jan 14, 2009 | SanDisk Sansa e260 MP3 Player
Sound to one earbud only.
The player should be replaced - the headphone jack or the headphone controller on the circuit are damaged, and these are nt orderable parts.
Jan 14, 2009 | SanDisk Sansa e250 MP3 Player
Plugged in headphones for call, now earpiece doesn't work
Same here. I tried many things but cannot ring it back to headset mode. I continuously see the headphone icon shown in the phone, so it seems that the phone thinks that it is still connected to earphones. Sometimes, it works fine, but mostly it does not. If I connect the phone on bluetooth earphones, it works fine.
Any help will be appreciated.
Mar 13, 2008 | Nokia 7370 Cellular Phone
Sansa earphones
first try using different headphones, if the problem isn't with the headphones then it's the mp3 you'll probably have to send it in to get it fixed.
Mar 04, 2008 | SanDisk Sansa E280 MP3 Player
Earphones stop working
I had this very problem. The Sansa worked great for over 1 year, but then I started getting some dropping out of sound on the left side. Today I went to an electronic shop and they opened up the unit. There was a small crack in the solder of the earphone jack on one side. So the electrician just used a fine point solder and fixed that, then strengthened the other solder points of the jack to make sure it won't happen again... I hooked in the earphones....and it is PERFECT again!!!! So, don't lose hope...just take it in to a decent electronics shop and they will most likely be able to fix your problem. And he only took around US$10 for the job. Beats buying a new player...
Mar 28, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
62 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
