Question about Plumbing
No hot water coming out of danze rosemont kitchen faucet. Cold water is slow.
5 Suggested Answers
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 35 Answers
SOURCE: slow running tap
If you have recently turned off your water supply you may have disturbed some sediment in the water lines causing this problem.....Unscrew the airator at the end of the faucet and there is a screen inside( take note how this screen is in place). This should give you water pressure back!
Posted on Dec 19, 2008
  • 23 Answers
SOURCE: bathtub water does not get hot enough-
take off handle and you should see a nylon ring with teeth just take off and put back in the oppisite direction that you removed it its there to prevent kids from getting burnt
Posted on May 12, 2009
  • 7 Answers
SOURCE: Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
Posted on Oct 17, 2012
Had new Peerless kitchen faucet installed and now the water pressure is VERY slow, both cold and hot. What can I do?
Aireator on end of faucet where water comes out has water saver inside with screen,unscrew and clean plus flush faucet,should take care of Richie Rich
Jan 26, 2011 | Plumbing
I have Danze, single handle shower faucets that were professionally installed in 2005. One shower faucet has not hot water, just cold and when the handle is turned on all the way to hot, there is an itty...
Replace valve canister- no construction- just remove after taking time to shut off water- a few screws and the job takes 15 minutes. I take for granted you have good water hot/cold to the fixture. This fix will cure most temperature balance problems.
The single lever system is a EZ care system. Note the canister can malfunction faster when exposed to untreated hard water.
Nov 17, 2010 | Danze & Single Handle Tub And Shower...
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
No cold water
Behind the handle there is a dial to adjust water temp cold and hot you can remove it and replace it a 1/4 turn til you can get both cold and hot. It is a anti scald it may have been put in wrong.
Make sure the cold water line is not blocked coming to valve and is open .
Mar 15, 2010 | Danze & Single Handle Tub And Shower...
Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Apr 13, 2009 | Danze D302521 Antioch Roman Tub Faucet...
I have a single handle kitchen faucet that now has no cold water
You need to install a new cartridge in the faucet.  The cartridge controls everything.
Mar 09, 2009 | Danze D403412 Melrose Single Handle...
Danz cartridge removal
Loosening the set screw behind the small plastic hot/cold plug will allow you to lift the handle straight up. You may need to jiggle it a little bit or twist it, just pull straight up with the faucet handle down and centered. Once the handle comes off, Then the collar should thread off exposing the inner workings of the faucet. You should then be able to unthread a bunch more components and washers until the cartridge top is exposed (depends somewhat on whether it is a pullout hose or seperate sprayer...not sure exactly what model you have but this is the standard for a single handle kitchen faucet...)
Here is a link to a page that shows how your (hopefully your) faucet goes together... also includes the re-order info for cartridge (#8)...
http://www.ajmadison.com/ajmadison/itemdocs/D403412-chrome_parts[1].pdf
I would also check the supply stops to make sure they are not clogged, because it is definetly a sediment problem.
Jan 23, 2009 | Danze Fairmont Double Handle Roman Tub...
Slow running tap
Dec 18, 2008 | Plumbing
Plumbing Logo
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
