Question about HP Deskjet F300 series
Cant clear a document from my printing queue
I've deleted it and it says "deleting" but it's not going away and I can't print anything
frcs68
  • 1605 Answers
SOURCE: Docs in queue won't cancel so I can print another document
turn of the printer and unlug the data cable.
go to start>>printer and faxes, open the printer queue and deleted the job.
plug in the data cable and turn on the printer
Posted on Jan 29, 2009
  • 684 Answers
SOURCE: Document in queue won't print.
In this case what i would request u to do is:
1. Let the Printer be Connected to the Computer......
2. Click on start then Click on Run or If Windows Vista Type Services.msc Under the Run Window if XP,Under Start Search if Vista.......
3. On that Services Local Window u need to find Print Spooler just Double Click on that and Click on Stop..........
4. Now let that Window still be Open now click on that start Menu Click on Run If XP........
Type in "Spool" and Click Ok...........
5. Double Click on Printers and Delete Each and Every File Inside the Printers Folder...........
6. Now Close this Window and now u will be back to the Print Spooler Window now u can click on Start under the Print Spooler....
Now Try to Print Will Work Fine....................
Good Luck :)
Posted on Mar 04, 2009
MUKHTAR
  • 2022 Answers
SOURCE: My print queue has hung trying to print an adobe
to delet the print job kindly do
In run window type services.msc and the go to print spooler option just stop and restart the service.
Posted on Jan 22, 2010
Hannibalwr
  • 99 Answers
SOURCE: I cancelled a print job from the Vista Printers
hi,
you need to delete the jobs and print the stuffs...
you need to give the following commands in the command promt which can be accessed from the start menu or by clicking "windows key+r"
net stop "print spooler"
to stop the print spooler
after you have stoped the print spooler
Browse to your windows\system32\spool\PRINTERS\ folder
You should see files there ending in .SPL and .SHD created around the time you tried to print – delete these files.
now try to print the stuffs..
if it clears the mess please give a vote....
Posted on Mar 11, 2010
  • 9 Answers
SOURCE: Seem to have a document
U have to clean the Print Spooler. What is Ur operating system? For example. in Windows 7 U have to: 1. Start > Control Panel > Administrative Tools > Computer Manager. 2. Select Services and Applications > Services. 3. In column Services seek for Printer Spooler and select it with the mouse. 4. Click right mouse button and select Restart. It should solve the problem.
Posted on Jun 09, 2010
What to do if after canceling the printing in queue document its status is still showing deleting ?
Give it a few minutes. Sometimes it takes awhile to delete the document.
If that fails, turn off the printer, wait a minute, then turn it back on. The document should be deleted.
Jun 29, 2015 | Office Equipment & Supplies
I cancelled a document while it was printing and it is still in my queue days later as deleting and it wont let me print anything else or restart that print job.
The best way to delete the print job is to turn the printer off, then disconnect the cable from the printer to the computer. Turn the printer on with the cables off, and go to your computer and delete the document, Then once it's deleted, turn the printer off again, and then hook the cable back up. Then turn the printer back on. That should do it.
Good Luck
Mark
Sep 13, 2014 | HP deskjet 3940 color inkjet printer -...
I cant get a print job to delete from the queue and its holding up all the other jobs
To delete print jobs stuck in the print queue on Windows:
  1. Click Start ? click Control Panel ? click Printers and Faxes.
  2. Right-click on the Lexmark print object and select Cancel All Documents.
  3. If that doesn't clear the queue, restart your computer.
If print job(s) still remain in the queue even after doing the steps above:
Stop the Print Spooler service from the Services console
  1. Click Start ? click Run ? type cmd ? click OK.
  2. Type net stop spooler at the command prompt ? hit Enter on the keyboard.
Clear the SPOOL folder
  1. Click Start ? click Run ? type spool ? click OK.
  2. Open PRINTERS folder ? delete all files in the folder.
Start the Print Spooler service from the Services console
  2. Type net start spooler at the command prompt ? hit Enter on the keyboard.
Try to print again after clearing the print queue.
Nov 24, 2010 | Lexmark Z611 InkJet Photo Printer
When the message "5 documents pending" appears but
Rebooting the computer may help get rid of the print jobs stuck in the queue. If not, follow these instructions carefully:
For Windows
  1. Go to Control Panel
  2. Go to Administrative Tools
  3. Go to Services
  4. Look for Print Spooler in the items. Double-click on Print Spooler -> click on Stop -> click Ok. Set the Services window aside.
Clear the Spool folder
  1. Go to Start
  2. Type Spool in the Search/Run bar, hit Enter.
  3. Open PRINTERS folder
  4. Delete all the files in the PRINTERS folder. Close the Window
Re-enable the Print Spooler
  1. Go back to the Services window
  2. Double-click on Print Spooler, and click on the Start -> Click on Ok. Close the Services window.
Go to Printers and Faxes and refresh the page. It should clear the print queue now.
For Macintosh
Simply launch Terminal and type cancel -a - That will clear the print queue.
Nov 09, 2010 | Lexmark X2600 InkJet Printer
MY LEXMARKX5650 THERE IS A DOCUMENT STUCK IN MY QUEUE. IT SAYS DELETING BUT IT DOESNT DELETE I CANT PRINT MY OTHER DOCUMENTS I REALLY DONT WANT TO HAVE TO RESTART THE PC IHAVE A FILLED IN DOCUMENT THAT...
Disconnect the printer from the computer. Open the print queue, and be sure that the title bar says "printer offline". If it doesn't, select "use printer offline" from the file menu. Then try to delete the file multiple times if necessary to clear the queue. You may have to reboot the computer, but try this first. Also, you can try pressing cancel on the printer itself. If none of this works, disconnect the printer from power for 10 minutes, and try again. Good luck!!
Sep 29, 2010 | Lexmark X4650 InkJet Printer
What do I do when there is a document frozen for printing on the printer. I have shut both the printer and the computer off to restart it. I have also tried cancelling the frozen document as well as...
Not sure if this helps, but you should first try to tell the system to delete or cancel all print packages. What is typically happening is that there is a problem with the first item in the queue, and all the others behind it or listed below it won't print eighter - by deleting the troublesome print, it may take time but it should clear - HP would often do that, but totally shutting down cold was the only way to clear the queue. When both the PC and printer did a cold boot, then the queue would be clear. If not then maybe check with the manu of your printer for their advice
Nov 06, 2017 | Dell Photo 964 All-In-One InkJet Printer
Print queue will not clear after printing
dear sir
this is a typical usb inkjet printer problem
just follow the steps
open notepad
and copy paste
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
and save as delete.bat file on desktop
run this file and reboot the machine
and run this file again
now print queue will get cleared
thanks
Apr 10, 2009 | Dell 966 All-In-One InkJet Printer
Printer document in queue will not delete
1. First, try turning printer off and on.
2. Next, on the computer side, this is how you manually clear the printer queue.
1. Go to Start, Control Panel and Administrative Tools. Double click on Services icon.
2. Scroll down to the Print Spooler service and right click on itand select Stop. In order to do this, you need to be logged in asAdministrator. At this point, no one will be able to print anything onany of the printers that are being hosted on this server.
3. Next you need to go to the following directory: C:WINDOWSSystem32spoolPRINTERS.Delete all the files in this folder. This will clear all print queues(it’s a good idea to first make sure there are no other print jobsbeing processed on any of the other printers on the server becausedoing this step will delete those jobs also)
4. Now you can go back to the Services console and right-click and choose Start for the Print Spooler service!
You can also go to a command prompt and type net stop spooler or net start spooler to start and stop the service.
I hope this helps. If you have more questions, let me know.
Dec 20, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Unable to stop printer from printing documents
The actual folder in Windows where spooled documents are stored just before printing is: C:\WINDOWS\System32\spool\PRINTERS. I?ve never had print jobs hanging around after the print queue has been deleted but if you clear out anything in this folder that should take care of it. Let us know how things work out and please don?t forget to rate this posting.
Mar 17, 2007 | Samsung ML 2010 Laser Printer
Computers & Internet Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
