Question about Garden
How to change the string on the 8061 efco garden trimmer
canbruce75
  • 1776 Answers
SOURCE: how to change string on weedeater trimmer electric
Check out the link that I am providing and see if the video helps you out. Sure hope so and best wishes.
http://www.youtube.com/watch?v=SuGfDNH6fXk
Posted on Aug 30, 2009
  • 53 Answers
SOURCE: I am trying to change the string on a Craftsman Weed Trimmer
Usually you "Push in" as you turn them. Or...there is a knob with a male thread shaft screwed into place holding it all tight. Hold the spool steady as you try to turn the knob off. Or...there is simply a "nut" to take off. But for the most part the newer wacker spools usually just "push in and turn/twist" out. Simple. to reinstall it or replace it with a new one simply push and twist it the opposite removal direction. FYI most lines can be manually "rewound/refilled" by yourself and reused over and over until they really wear out. There are little tricks to doing a rewinding but it isn't anywhere near difficult to do...or learn. Usually the price of a replacement spool is 5 times the cost of rewinding them yourself. Comon its easy! If ya want I'll help ya thru it.
Posted on May 10, 2010
  • 18 Answers
SOURCE: The string on my spool ran out.
• Turn off the trimmer and remove the battery
• Press the release tabs on the line spool cover and remove the cover by pulling it straight off. replacement spool is AF-100
• Lift the spool of nylon line out of the hub and clear any broken line and debris
• In case of jams and tangled line unwrap about one foot (30cm) of line to ensure that it is undamaged. If it is OK rewind it and insert the line end through the eyelet in the spool hub.
• Pull the line through the hole to maintain tension while placing the
spool down into the hub with the notched side exposed.
• Press the spool down GENTLY and rotate it until you feel it drop into place. (When in place, the spool will turn a few degrees left and right freely.)
• Snap the spool cover back on.
Posted on Jul 08, 2010
  • 17 Answers
SOURCE: how to load string into trimmer head
pull head off cut 1 piece of line bout 48 inches should be a **** in center of head put center of line in slot then roll line in same direction in both slots lock ends in head reinstall
Posted on Jul 15, 2012
ka4iup
  • 3960 Answers
SOURCE: how to string a talon garden hawk trimmer
https://www.youtube.com/watch?v=tXUrdUoS_PU
Posted on Mar 18, 2015
Testimonial: "thanks it was helpful but they show how to spools with holes not splits"
How to put a new battery cable on my troy built weed eater model # tb22ec?
I don't think this item has a battery
Troy Bilt TB22EC 41ADT22C966 25cc 2 Cycle Curved Shaft Trimmer Parts
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/equipment/troybilt/TB22EC-trimmerTB22 EC Curved Shaft String Trimmer. 25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design Model No. 41CDZ22C766 .
Jul 31, 2017 | Troy Garden
What is the fuel mix for efco tg2600xp
25:1
CAUTION: DO NOT USE AUTOMOTIVE OIL OR 2-CYCLE OUTBOARD OIL
Jul 28, 2017 | Efco Garden
I changed the string in my ryobi 725r and since then it feeds the string so fast it wraps around the shaft. What did I do wrong?
multiple failures with bump advance string trimmers - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Jul 5, 2008 - I have indeed hurled my own ryobi across the yard in a fit. ... Some heads are not designed for curved shaft trimmers or on engines under a .... the fence so thestring won't wrap around the fence instead of whipping in and out.
Sep 30, 2015 | Ryobi Garden
How to install string for ryobi 50 volt string trimmer
Line Trimmer Line Replacement of a Ryobi One+ 2013 ...
? 2:33
www.youtube.com/watch?v=8jEER8lHUQk
Feb 22, 2013 - Uploaded by TheLegoCityBoys How to replace line in a garden Line Trimmer. ... Ryobi 40-VoltLithium-Ion Cordless String Trimmer RY40210 - Real World Review & How To ...
Aug 08, 2015 | Ryobi Garden
How to tune poulan pro 25cc trimmer
The only tune you can perform is change plug, air and fuel filter. Check fuel lines and make sure they are in good condition.
Jul 13, 2014 | Poulan 25cc 2-Cycle Gas Powered String...
I have an electric 13"
you can try a smaller string size, this should help. Tim
Apr 24, 2011 | Toro& Electric String Trimmer
Can I re-string the trimmer head or do I have to buy a whole new one. I have aEM4251CA string trimmer
You can restring it. If you don't have the manual to show you how to do it bring the head with you to a tool hire shop that deals in garden machinery and they'll supply it and show you how to fit it.
Jan 09, 2011 | Makita EM4251 16" 4 - stroke String...
Need to replace string in RTE115C, instructions feeble Checked everywhere...ready to trash and buy some other brand.
Oddly enough, the string head appears to be identical to the one for their gas model. Some poor engineering and design here. Before you buy another model, maybe take a trip to Home Depot and in the lawn and garden section you may find several trimmer parts for different models, including a Universal String Head. Try changing out the head as the stock one is a headache for many users.
Nov 19, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
String is cut always
first of all be carefull of what you hit with the trimmer string if you hit sidewalks and rocks or dirt it will cut it short also you might make sure the tensil strength is strong enough to withstand the abuse the trimmers being subjected to :-)
Jun 22, 2009 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
