Question about Sanyo DS31590 31" TV
SANYO DS32224 I LOST REMOTE CONTROL AND MENU OPTIONS IN RED I CAN NOT GET INTO
    Scholar:
  • 170 Answers
Menu options are red, on most i have seen these are red because your on input and those options can't be adjusted in input mode.
Posted on Mar 04, 2008
    Genius:
  • 1,554 Answers
Here or ebay
http://www.remotecontrolscenter.com/sanyo/
Posted on Feb 25, 2008
2 Suggested Answers
SOURCE:
SOURCE: SANYO DS32224
I have this problem as well..have tried many universal remotes..still cant access menu options
Posted on Dec 24, 2007
Where is the mode button so I can sync the remote and the tv? what is the 3 digit code
Hello
Three digit universal remote codes for Sanyo are:-
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote codes for Sanyo are:-
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON the tv by its front panel power control switch [Not by remote control handset] each time before an other code.
OK
Wish you Happy Peacefull 2011.
Dec 30, 2010 | Sanyo DS32224 TV
Black square on left side of screen
hi,
i think ur tvs closed caption option is in ON position. if it is ON then there will be a black square int left side.
1. press the "CAPTION" key on the remote control.
2.press "0" key on the remote to select options- OFF, CAPTION 1, CAPTION2,TEXT1,TEXT2,AD QUICKCAP.
select it to OFF mode.
ok
Dec 22, 2010 | Sanyo DS32224 TV
Lost remote control can I get another one
contact sanyo at sanyo.com follow instructions to replacement parts
Mar 09, 2009 | Sanyo DS32224 TV
TV is stuck on video 1?
You probably have a replacement remote. It will need to be reprogramed to your tv. You should have instructions that you got with the remot. Otherwise call your TV repair man and he can probably "walk" you through it over the phone.
Jan 12, 2009 | Sanyo DS32224 TV
Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Apr 26, 2008 | Sanyo DS32224 TV
Sanyo DS32224 TV blurry
Do you have the original remote for that TV set? If you do not, you will need to get one or borrow an original Sanyo remote so you can get into the set's menu and go to puicture set up and try adjusting the constrast up a little bit.
Mar 20, 2008 | Televison & Video
Ds3224
push reset on remote twice quickly
Jan 05, 2008 | Sanyo DS32224 TV
Setting up remote for tv
If you are using the remote that came with the TV, it is already programmed for it. If you are using a universal remote such as a Logitech, RCA, Sony etc. go to the appropriate web site for support and remote codes for your TV. Good luck..
Dec 04, 2007 | Sanyo DS32224 TV
SANYO DS32224
Dec 02, 2007 | Sanyo DS31520 31" TV
Sanyo DS31590 31" TV Logo
190 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
