Question about EdgeStar BWC90SSLT - 84 Can Supreme Cold Beverage Cooler - Black and Stainless Steel
Edge star not cooling and clicking sound
Fridge not cooling and making a clicking sound.
  • EdgeStar Master
  • 2,237 Answers
The clicking sound may be the condenser fan. if the compressor is running, check to see if there is dust or ice blocking the air flow on the condensor or if the fan is moving slow. this will prevent cooling. remove any obstructions and replace the fan if necessary
Posted on Feb 26, 2014
The fridge stopped working last night. The light works, but the fridge just makes this clicking sound every couple of minutes, doesn't sound like anything is running and it does not get cool at all. Any...
Not a good sign, clicking. Usually that click comes from the compressor power circuit. The compressor is attempting to start but it does not. The clicking is from an overload protector that heats up from current draw. It clicks and cuts the power to the compressor, cools down, and the cycle starts again. Could be a start capacitor went bad, but it is probably the compressor.
Mar 11, 2015 | Refrigerators
Our fridge is making a clicking sound. The freezer and the fridge part are not cooling, however the lights stay on. There is no running from the motor either. The clicking sound is comming from the back of...
there is mother board in the back the noise is the interlock that clicking... most of the time it happen the board is dead and need to be change.
if you poll the unit out you will see the bracket that cover the board...
let me knoe if you need more help
Jan 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
Is kenmore refrigerator model 71182 energy star ? the fridge is only cooling to 50. we defrosted the freezer because ice tray water kept missing and frosting up freezer, now fridge doesn't cool well...
go to www.applaiincepros.com and look up your modle it could be the defrost timer but not sure, if the fridge was built after 1991 it is energy star, but there are big differences even from 5 years ago on energy useage.
Nov 12, 2009 | Kenmore 71182
CONSTANT CLICKING SOUND COMING FROM POWER BOX
if the fan blade is contacting anthing under there and stops it will shut down the compressor and wont work
Aug 23, 2009 | Refrigerators
Clicking sound from rear of Jenn Air Premier Line Fridge
Simple relay replacement, if you do it yourself you are looking at about 65 dollars max, you call a repair company you are looking at 245 or more
Feb 09, 2009 | Jenn-Air Premier Line Energy Star Cabinet...
Freezer not working , clicking noise coming from fridge
Clicking was a relay. Replaced relatively inexpensive relay and now working fine.
Jan 17, 2009 | Jenn-Air JCD2389G Side by Side...
Orange star button inside fridge
There is a defrost timer that starts the defrost. It may be in the section where the temperature controls are located. You will find a round hold with a clutch head screw accessible through the hole. Turn the screw clockwise SLOWLY until you hear one audible click. The system should then be in the defrost mode. Wait about 25 minutes and if the timer is good the system should go back into the cooling mode. If it does NOT, advance the timer to the next click and get a replacement timer. The defrost should have taken place if there is no other problem. If the unit went back into the cooling mode and defrost did not take place your problem is in the freezer section behind the rear wall. There you will find two items, a defrost heater and a defrost thermostat. You can check out the heaters with an Ohm meter. No reading, open, means replace the heater.
Jun 29, 2008 | Haier HTX18GAAWW Air-Cooling And Automatic...
Not cooling, no ice or water, making clicking sound
Sounds like the motherboard went out. Might need to replace the appliance or the board. Im not positive though. Hopes this helps....
Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
EdgeStar BWC90SSLT - 84 Can Supreme Cold Beverage Cooler - Black and Stainless Steel Logo
117 people viewed this question
Top EdgeStar Kitchen Appliances - Others Experts
Colin Stickland
Colin Stickland
jasbo
jasbo
Are you an EdgeStar Kitchen Appliances - Other Expert? Answer questions, earn points and help others
