Question about Kobo Vox K080-KBO-B Reader
Kobo obtaining ip address
Can't connect to the internet. Message is "obtaining ip address", then "disabled".
I have a problem with a internet connectivity in the task bar its showing aquiring network address
Acquiring network address (Limited or no connectivity)
1.Check whether you are typing the correct key
2.Remove the preferred networks
3.Disable WLAN/LAN and Enable it
4.Assign static IP address in the range of modem
5.Add the network manually with the security settings
Apr 04, 2010 | Lenovo ThinkCentre® A51 PC Desktop
I cannot connect to the internet with my linksys wrtu54g hotspot. It was working until 2 weeks ago. I get error message that says - a network card is incorrectly configured. The card should be able to...
The network card should be configured to obtain a IP address automatically,
Open Control Panel - click on Network Connections - right click on the network/wireless card - select Internet Protocol (TCP/IP) and click on Properties and then enable Obtain an IP address automatically and enable Obtain DNS server address automatically.then click OK and click OK again.
Dec 21, 2009 | Linksys Wireless-G WRT54G Router
No ip address
when you say ip/config you mean wifi properties and internet protocol properties right ?
if so select obtain ip address auto and select obtain dns auto.
if thats not what you mean...goto control panel ..open network connections...click on ur network connection ...in the list at left select change settings for this connection...in network properties scroll to internet protocol..double click to open..select obtain ip auto and obtain dns auto.
there are other ways to fill in fields but you need relevant info..
there are programs which can show u ip's but most require a special driver.
incidently if you choose ip and dns auto you will not see ip address but when connecting to network you will see aquiring ip address please wait.
if for some reason you still cant connect go to a place where you know have free internet access and connect there then net connection will be configured
Jan 25, 2009 | Computers & Internet
I have lan with internet connection via switch... but only one machine is working.. remaining machines r not woriking... it shows locan are network cable unplugged.. switch is working properly....
Check TCP/IP Properties and Advanced settings at each non-working PC (i.e.to obtain IP address automatically, DHCP is enabled, obtain DNS, etc) that the network cards are not disabled and also configured correctly. Also check "Internet Connection Sharing" options are correct. Check cables, link lights. Ping and that theres a reply to each address.
Dec 29, 2008 | Computers & Internet
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
Keep geeting an error message another IP address has been detected. I have a wireless router & laptop, and a desktop whcih the the main computer.
If you have Vista,
  1. Go to START > CONTROL PANEL
  2. Under Network and Internet, click VIEW NETWORK STAUTS AND TASKS
  3. On the side panel, click MANAGE NETWORK CONNECTIONS
  4. Right click your Wireless network, and click PROPERTIES
  5. Single-Click Internet Protocol Version 4 (TCP/IPv4)
  6. Click Properties
  7. Write down all the infromation in case you need to type it in again later.
  8. Click "Obtain an IP address automatically" and "Obtain DNS server address automatically"
Sorry, but I cannot help with XP at the moment.
Mar 06, 2008 | Computers & Internet
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Settings for my browser
If you use Internet Explorer: Go to Start, Settings, Control Panel, Internet Options, Connections, and the LAN Settings button. Clear all checked settings in this window. Then, open your browser and select the Tools menu. Under Internet Options, click on the Connection tab and make sure that "Never dial a connection" is selected. If possible, remove all the connection settings. If you use Netscape Navigator: Go to the Edit menu and select Preferences. Go to Advanced, Proxies, and click "Direct Connection to the Internet." Also check for the following. If you are running Windows 95 or 98 or ME: Click on the following tabs and write down the settings you find. Right-click on Network Neighborhood and select Properties. Select "TCP/IP" for your network adapter. Then click Properties. Click the IP Address tab and select "Obtain an IP address automatically." Under wins configuration, click on use DHCP for wins resolution Click the Gateway tab. If there are any "Installed gateways," highlight them and click Remove. Click the DNS tab and select "Disable DNS." Click OK If you are running Windows NT: Write down any settings you see throughout the tabs for future reference. Right-click on Network Neighborhood and select Properties. Click the Protocols tab, highlight TCP/IP, then click on Properties. Click the IP Address tab and select "Obtain an IP address automatically." Remove any gateway settings you see. Click OK. If you are running Windows 2000: Right-click on My Network Places. Click on Properties. Right click on the Local Area Connection icon that connects to the Router. Click on the Properties button. Highlight TCP/IP, then select "Obtain an IP address automatically." Click OK. Go the the advance tab, click on wins, check the box use NetBios settings from the DHCP server. If you are running Windows XP: Click on My Network Places. Click on view network connections. Right click on the Local Area Connection icon that connects to the Router. Click on the Properties button. click on the advance tab, make sure the internet connection firewall is not checked, click ok,Highlight TCP/IP, then select "Obtain an IP address automatically." Click OK.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
How can i verify??
Feb 16, 2006 | Belkin (F5D5230-4) Router
Kobo Vox K080-KBO-B Reader Logo
20 people viewed this question
Top Kobo Cameras Experts
Are you a Kobo Camera Expert? Answer questions, earn points and help others
