Question about Microwave Ovens
MAYTAG MDB7749AWQ2 reset and all the lights are on.
RESET DISHWASHER AND ALL THE LIGHTS ARE ON.
A small blinking light on the left upper corner of panel after a power outage and I can't do any command. The interior lights don't even come on when opening door. I already reset the breaker
Unplug the microwave oven for 10 minutes in a attempt to reset the microprocessor ic, press and hold the start button for the same time and release. Now plug everything back in hopes it will restart, if no change! the keypad control board will need to be replaced along with other unknown parts, due to the nature of damage far cheaper to replace.
May 09, 2012 | Microwave Ovens
MCO160 microwave and cook vent appliance problem--there was a power surge and now only the light works--is there a reset button?
no reset button. if you are getting lights that means you are getting power and all your fuses are good. you may have a bad control board caused by the surge
May 12, 2011 | Magic Chef MCO160UQ Microwave Oven
I have noticed that when I have my dishwasher on, and kettle and water filter that the safety switch trips out, shutting down most of my kitchen. The dishwasher has it's own outlet and the kettle and...
all kitchen appliances should be on ground fualt outlets & breakers,If an appliance is on a g.f. outlet it should only blow that particular outlet so all you have to do is push the reset button.Outlets and lights should be on different breakers,so that if the outlet breaker blows you will still have lights
Oct 11, 2010 | Microwave Ovens
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
Loss of power
There would not be a reset button, but a hard reset can be done by unplugging it for a minute or so, then plugging it back in.
If that doesn't work, chances are you have a fuse blown in the microwave.
It's usually behind the grille, which is held in place by two screws.
Let us know what you find.
Oct 18, 2008 | Maytag MMV5207A Microwave Oven
Maytag umc5200aas Microwave is totally dead.
Be careful, a Microwave can be a death trap. Check outlet to make sure it's live. Could be a failed low voltage transformer.
Apr 23, 2008 | Maytag MMV5000 Microwave Oven
MMV5000BAW maytag over-the-range microwave
Found this in the GE section instead of Maytag, but we're happy to answer it anyway.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
If not, you may have a shorted keypad or bad control panel, either of which we can repair economically.
Please write back with more details if you need further help.
Nov 25, 2007 | GE JVM1870 Microwave Oven
Maytag microwave overheated.
There is a fuse that should be easy to get to behind the control panel.  Will need to take the grill off first to get control panel off.  Make sure unit is unplugged first.  There are high voltage parts in a microwave so you should have a professional do the work if you are not comfortable with it.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
