Ariston wash/ dryer ARMF 125 model error F13
Pls help how to fix it as error F13 showing, unable to operate the washing. Pls advise
  • 209 Answers
SOURCE: aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
Posted on Sep 14, 2007
  • 100 Answers
SOURCE: Hotpoint Washer Dryer WD865 - Dryer Problems
thermister blown or thermal fuse which is a black plug in the top of the dryer box or yellow sleeved wire, if it was noisy maybe the fan has come loose from it's motor. you will need to remove the dryer box on top of the drum to see if the fan is binding. you can push it back to where its not binding and tighten the nut-ANTICLOCKWISE, LEFT HAND THREAD.
usually the machine runs through a check before starting a cycle and will see an f13 and not start even a wash., so you will need to replace the blown parts.
Posted on Jan 28, 2009
  • 78 Answers
SOURCE: Ariston - Margherita Washer -dryer model AWD
Check motor brushes for wear. Brush length is about 30mm new; 10mm or less is too short to do what they're meant to.
Posted on Feb 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: Error code F13 is showing
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 07, 2010
  • 713 Answers
SOURCE: hi sir we have ARISTON washer and dryer model :
unplug it for a few min. plug back in.
Posted on Mar 01, 2011
F13 fault showing on my Ariston margarita 2000 awd12 washer dryer and the control Knob keeps continuing to turn endlessly. What could be the problem. Yours desperately John Russell
From memory I think this is a dryer temp. sensor error. Check youtube out with query; "Wash Machine F13 error code". A company in England, eSpares, posts a few vids to help. I've bought a few things from them, very helpful and good prices. I have no connection with eSpares, accept an occasional customer. If you can do it yourself it is a quick, inexpensive fix. Good luck.
H
Apr 03, 2016 | Washing Machines
I have an ariston washer dryer combo. today I turned it on to do a wash cycle. the knob no longer clicks or shows the times of other cycles. I've turned it off and on a few times but nothing helps
Ariston armf 125 washer dryer combo - YouTube
? 4:14
www.youtube.com/watch?v=zPtG5Q3qQ3Q
Oct 23, 2010 - Uploaded by troykm Rinse cycle. Correction - it does do 3 rinse cycles!! :-)
[PDF]Instruction Manual - Ariston Appliances
aristonbrand.com/media/WDG-8629-User-Manual-19510586801_AU.pdf
WASHER-DRYER ! This symbol reminds you to read this instruction manual. ... from its packaging. 2. Make sure that the washer-dryer has not been damaged.
Sep 22, 2015 | Washing Machines
Ariston arwdf 129 error f13 flashing what does its mean?
I've had a quick look through the instruction manual, but was unable to find anything.
http://www.aristonappliances.us/_pdf/manuals/ARWDF129.pdf
Perhaps contact the manufacturer for more information?
http://www.aristonappliances.us/raccontaci.asp
Nov 10, 2014 | Washing Machines
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Lavadora secadora ariston aqualtis aqm8d error f13
F13: NTC wiring harness disconnected from the dryer system
1. Check the efficiency of the terminals on the CNA connector board
2. Check NTC wiring harness
3. Check the wiring harness continuity of the CNA / NTC connectors
4. Replace NTC
5. Replace terminal board
Dado
Apr 08, 2014 | Ariston Technologies AWD 129 NA Washer/...
F13 error code on Ariston washer dryer combo
Model ARMF 125 with same error code F13 how to fix please advise Thks
Nov 06, 2011 | Hotpoint-Ariston ARWDF129NA Washer
When i set my drier to dry on high heat it keeps tripping the electric with error code f-13 please could you advise me on why this is thanks
Indesit (Hotpoint, Ariston) 'F13's refer to 'thermistor circuit fault', 'dryer fan not working', 'dryer NTC (thermostat) fault' and other similar things! There CAN be problems with poor connectivity between cables and plugs/ sockets which could cause similar symptoms. It realy needs a service call to identify/cure, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 16, 2011 | Hotpoint Aquarius WD640 Front Load...
It appears F13 error
hi sir we have ARISTON washer and DRYER model : AQXXMD129EX its a error coming F13 please help me soon
Dec 21, 2010 | Ariston Technologies AWD120 13 lb. Washer...
Hi, I had purchased second hand MARGHERITA 2000-AB63 Washine Machine. BUt i dont have manual to operate. Pls Help.
i have ariston marghrita 2000 AB 63 it does not clean cloths and does not dry cloths.whenever i takeout cloths they are so wet that water drops out of these cloths. pl tell me what shall be position of different buttons and knob when i wash wash cotton/tetron mix cloths
Oct 25, 2010 | Ariston Technologies Ariston AWD12 Front...
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
