Question about Ovens
Defy gemini gourmet
Just got a second hand one the top grill doesnot seem to work and the knob goes right round
4 Suggested Answers
protek480
  • 1714 Answers
SOURCE: Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Posted on Sep 03, 2009
Testimonial: "very useful thanks"
reddyanantha
  • 205 Answers
SOURCE: grill control knob broken
hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Posted on Oct 04, 2009
SOURCE: The bottom oven of my
I cant find the fuse please can you post more details
Posted on Jul 27, 2011
Where is to cut out switch located in a gemini petite oven
if the oven is wired in to the house correctly
all ovens are hard wired into the house wiring
will be a trip switch marked" oven" on the house main power board outside ..
a fautly oven cant be used at all
call electrician for testing
ring for take out or home delivery meals
user manual link
OVEN DEFY GEMINI PETIT CHEF
https://www.defy.co.za/wp-content/uploads/.../Gemini-DBO472-DBO473-Manual.pdf
Oct 10, 2016 | Ovens
I have a defy Gemini gourmet double oven. The top oven works but no light. The bottom oven there is nothing not even the clock is working. What could be wrong and how do I fix it?
First check and make sure you are not in Sabbath mode in the manual. if you are not in that mode then most likely your oven went over temp and the thermal fuse shorted out. You would need the fuse and most likely a temp sensor because it went over temp. I am not there to do tests but that is what is most likely.
Jan 18, 2016 | Ovens
Use grill on whirlpool double oven
Depends what model but on mine you have to Turn right hand knob round to grill and then turn middle one round to desired temp, I use max 11.
hope that helps
Mar 02, 2015 | Whirlpool Ovens
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
The temperature markings on the top oven/grill have worn off - can anyone help
the first knob has tree positions in the middle is off to the left the top (grill) heats to the right top (grill) and bottom heat, the second knob indicates the temperature in the following way ..50....100....150....200....250..good luck
Nov 27, 2012 | New World E70DOa Electric Double Oven
Model 720EF. Model No 059040415. The grill will not work. The top oven is still working but the grill light or fan will not come on at all. Stoves have told me over the phone that it could be the...
First things first. The top oven lights ONLY come on when the top oven is switched on. Operating the grill DOES NOT turn the lights on. If you wish to see what you are grilling, you have to turn the top oven control knob on to its first position as well as turning the grill on.
Secondly, the grill only works when the door is open. The grill does not work when you shut the door. When you open and shut the door, you should be able to hear the microswitch operating. It is located in the right hand side of the cooker, between the inner and outer panels - you cannot see it. I haven't seen the switch first hand but they normally come with an arm that contacts the door mechanism and the door mechanism operating, causes the arm to move, which causes a button on the switch to move and make the circuit. It has been known for the arm on the microswitch to bend with use so it no longer works correctly.
If you have checked all above and you hear the switch operating, then it could have failed. They are quite common, so if you can't get one from STOVES, try espares or someone like Maplin or RadioSpares.
The get to the microswitch you have to take the oven out of the housing and then take the right hand panel off. You should then be able to see it and check its operation.
All the best
Jul 26, 2011 | Stoves 720EF Electric Double Oven
I bought a house with a Defy Gemini Petite Chef oven but it is not working. The oven flicker on Auto. How can I delete the Auto?
Most models won't work when on Auto. There are push buttons under the clock and one has a picture of a hand (Like a cop holding up his hand to say "Stop"). From left to right numbering the buttons 1-6, this is button 4 on your appliance. Press this button and it should go back to manual mode and allow you to use the oven.
You can download a manual for this appliance from here:
http://www.google.co.uk/url?sa=t&source=web&cd=1&ved=0CBoQFjAA&url=http%3A%2F%2Fwww.defy.co.za%2FgetFile.asp%3FPath%3DD%3A%255Cinetpub%255Cwwwroot%255Cwww.defy.co.za%255Cimages%255CManuals%255C061_896_Gemini_Petit_Chef.pdf%26File%3D061_896_Gemini_Petit_Chef.pdf%26Size%3D342953%26Name%3D061_896_Gemini_Petit_Chef.pdf&rct=j&q=Gemini%20Petite%20Chef%20manual&ei=WfAWTqmnOsmYhQeotZHMBQ&usg=AFQjCNFC3Mdb5clrC_aHL8sq4P0zkfhmZA
Or google " Gemini Petite Chef manual " and the first hit has the link
Jul 08, 2011 | Ovens
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
I have a defy gemini petit chef multi function themofan oven but dont have a manual on how to use would you be kind enough to let me no how to us it thanks naaz
i have a defy gemini petit chef thermo fan oven.I only used it for about 20 times the warranty is over the fan works but the elements are not getting hot both the grill and bake.could you please tell me what the problem could be
Apr 01, 2009 | Ovens
Ovens Logo
14 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
