Question about Acer Aspire 5050-3371 Notebook
Operating system not found exiting intel UNID, pxe-2.1 (build 082)
  • 8 Answers
SOURCE: ACER Aspire 3050: Operating System not found
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Since the computer is on, immediately start to press F2 or DEL button in order to enter the BIOS and reset all settings to default. Most likely you turned on the «Boot from network «option.
Posted on Sep 30, 2008
  • 177 Answers
SOURCE: operating system not found
First enter your bios setup by pressing F2 when your computer starts. Find the section which sets the boot device order. Change the first boot device to CDROM. Save the settings and exit bios. Now put your recovery CD in cdrom drive and see if it runs.
Let me know if it does not work
Posted on Nov 26, 2008
  • 707 Answers
SOURCE: no bootable CD in ATAPI
try downloading from here
http://pci-ven.com/driverdetector/realtek/rtl8139realtek/realtek-rtl8139-x-8130-810x-pci-fast-ethernet-controller-v2-17-051202-.html
good luck
Posted on Nov 08, 2010
ratonxi
  • 112 Answers
SOURCE: intel UNDI, PXE-2.0 (build 083) Copyright
That message is because the laptop is trying to boot through the network. You have to change the boot order in the BIOS, and put on first place the hard drive. Press the F2 key just before turning on the laptop. You should go to the bios program. On the bios, search for the Boot tab-move with the directional keys- you should see something like this: http://slackworld.berlios.de/2007/images_vmware/vm-bios-cdrom-boot.png. Press F5/F6 to move the hard drive on top. Then press F10 key, hit "Y" and then "enter". The laptop will reboot and it should boot through the hard drive-on which you have windows. If with hard drive on top, you still get that messsage, you will have to reinstall windows-it means that the files in the hard drive are corrupted- or replace the hard drive.
Posted on Jan 03, 2011
SOURCE: Intel UNDI, PXE-2.1 (build 082) Copyright (c)
I get this same and won't go any further
Posted on Jan 12, 2012
INTEL UNDI, PXE-2.1(BUILD 082) COPYRIGHT (C) 1997-2000 INTEL CORPORATION ..RTL8111 PXE-E53: NO BOOT FILENAME RECEIVED, PXE-M0F: exiting PXE ROM NO BOOTTABLE DEVICE--INSERT BOOT DISK AND PRESS ANY KEY
Could be your HDD is faulty and has errors. Could be you have upgraded to Win10 and the system cannot find the boot sector now. Will it boot from a DVD ROM?
Jun 10, 2016 | Intel Computers & Internet
This is what mine says when I turn on Intel UNDI, PXE-2 . 1 (BUILD 082) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check cable connection..
You hard drive is missing from the system. Just does not recognize it.
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 25, 2012 | Acer Aspire One Netbook 8.9" Notebook
Hi i just switch my laptop aspire 6920 on and its start beeping and then its show me Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel Corporation For Atheros AR8121/AR8113 PCIE Ethernet...
enter to bios setup and remove Ethernet controller from boot sequence or make it last on the list. and about operating system not found if you already use your system without problem then reinstall the system from a cd .
Jul 23, 2011 | Acer Aspire 6920 Notebook PC
How do i fix my laptop if it don't start and it says intel UNDI , PXE-2.1 (build 082) copyright (c) 1997-2000 intel corporation for atheros PCIE ethernet controller v2.0.0.4(03/03/09) client mac...
Your laptop can't find an operating system, check the operating system as it installed properly. If its is then you need to check the hard disk drive of your laptop because it is missing from the motherboard.
Jul 21, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
How do i repair my pc it gives a message that says Intel UNDI, PXE-2.0 (build 082) Copy Right (1997,1998,1999)Intel Corporation VIA Rhine II Fast Ethernet Adapter V2.43 (2005/12/15) PXE - E61: Media test...
Dear,
If you are using PC then make sure that Boot from PXE Rom is disable and boot from hard disk drive is enabled. Check your BIOS setting for configure it.
Regards,
Rakesh Kumar
Network Support Engineer
Apr 07, 2009 | Compaq Computers & Internet
Argh girlfriend spilled hair gel on my laptop
thats ethernet card realtek
did you check to see hard drive is securely in tack
saying can't find os
you may need to do a new install let me know
if you took apart you made have caused hard drive to become lose
Jan 17, 2009 | Acer Aspire 3610 Notebook
Acer Aspire 9410-4933 not booting up
YOU NEED TO REINSTALL OPERATING SYSTEM ... FORMAT THE ACTIVE PARTITION AND REINSTALL
Sep 15, 2008 | Computers & Internet
Sep 11, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5050-3371 Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
