Instruction manual for pacific pcr55w Radio
Want to change the time
Free manual for a midland pacific vhf hand held radio
To download the manual, click 'Midland Pacific' (sixth from bottom) on the list of Midland manuals on this page:-
www.midlandradio.eu/manual/manuals_en_190875.aspx
The English language section starts on page 16.
Jul 17, 2014 | Midland Radio Communications
I want to change time zone CKS3030
Press and hold the Time Zone button. (It's the third from the left on the top arch; time is the button just to the left of the Time Zone button). Then press the + or - button to change the time zone (1 = Eastern, 4 = Pacific).
The manual for the CKS3030 is available from Emerson here: http://www.emersonradio.com/resources/owner_manuals/manual_1312918421.pdf .
I hope this helps.
Nov 06, 2011 | Emerson Smartset Clock Radio
Sentry self setting atomic clock lost the instructions
Select The Time Zone - For Sentry Self-setting Atomic Clock (ATC - 10)
The default time zone is Pacific zone.
1. In the normal time mode, press the MODE key to enter the alarm time mode.
2. Press the SET key to change the time zone.
each press of the SET key will move the time zone back one hour
P= Pacific M=Mountain C=Central E=Eastern
3. Press MODE key when correct Time Zone is highlighted.
I think the Instructions may tell you to use the ADJUST key instead of the SET key.
ADJUST key does not work for TIME ZONE change, SET key works.
This will set your clock to your chosen Time Zone for normal time.
Instructions for the ATC20 are located at the following url
http://www.sentryindustries.com/pdf/instructions/ATC20_instructions.pdf
Sep 28, 2010 | Office Equipment & Supplies
Got mine yesterday and its set on eastern time zone, i need pacific time zone and it will not sync, how to manually adjust ime
You should be able to set your watch to the Pacific time zone.
f you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
You shouldbe able to find the setting method in the manual.
May 12, 2010 | Casio Atomic Timekeeping WV58A 9AV Watch
We have an atomic clock with calendar and temptature on it. We changed the battery and it is now on Eastern time zone, not Pacific time zone. How do we set it? It is La Crosse Technology Radio Model #...
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
Feb 20, 2010 | La Crosse Radio Controlled Atomic Clock
How do you set the alarm for pacific standard time on the emerson
Here is the procedure for setting the time zones for your Clock/Radio. Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time I will give you the web link for the owners manual so you can find any other information you might need for your Clock/Radio. (http://www.emersonradio.com/owners/iPod%20Series/iC200_042007.pdf) copy this web address and paste it in the address bard of your browser and it will take you to a pdf copy of the owners manual. I hope this information help you with your problem.
Apr 27, 2009 | Emerson Smartset Clock Radio
I need to change time zone on atomic clock to EST
I need help setting the time zone on the sharp atomic clock model #spc364.
Apr 18, 2009 | Bose Wave Radio
Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
Jan 25, 2009 | Oregon Scientific FM Weather Projection...
Can not change the Brookstone Projector clock from Pacific time. We live in eastern time zone. where do I get a manual
Choosing a time zone. To select Pacific, Eastern, Mountain or Central time zone, press ZONE button inside battery compartment of clock unit.
Nov 11, 2008 | Audio Players & Recorders
35 people viewed this question
 Grubhead
Grubhead
