Question about Bosch Washing Machines
Toshiba e21 - Bosch Washing Machines
How to clear error 2 on a fully automatic toshiba washing machine
Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
https://www.skypesupports.com/
May 30, 2018 | Washing Machines
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E21: Lid open
E31: Load imbalance
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
How to fix error e21 with my toshiba electric washing machine AW SD130SS. It washes only. No rinse , no spin.
YOUR LID SWITCH IS GOING UPSET
CHECK YOUR DOOR LOOK AND UNDER SWITCH WIRE IS OK
Oct 06, 2017 | Washing Machines
Toshiba washing machine When I push on the error E7-4 shows and then it turns off what is E7-4 error ?
Is your machine either the Toshiba AW-SD120SM or AW-SD120SS?
If it is I checked the manual and the error code you mentioned is not listed in their operators manual. On page 35 of the manual there is a message that says "As for information display beyond the above-mentioned details, or the above-mentioned solutions do not work, please disconnect the power plug and contact technicians for repair."
The only codes mentioned are: E1 E21 E23 E31 E32 E5 A ans F
Jul 31, 2016 | Washing Machines
What does error code mean e21
Manual says E21 is 'Off Line'. Not much to go on there but I am guessing that is probably referring to something that is plugged into the serial ports on the side - perhaps it is looking for an external kitchen printer of something along those lines.
Jul 09, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
E2 error code aw-8990st toshiba wash
E21: Lid open
E31: Load imbalance
Hope this helps
Jan 25, 2014 | Washing Machines
My AW-1190S toshiba washing machine was showing error code E2-3
My Toshiba aw1190s shows error code E21. What the problem.. Tq..
Nov 22, 2012 | Washing Machines
Treadmill not working. Troubleshooting: Receiving E21 message. What does E21 indicate?
The E21 error code indicates that the console is not receiving a signal from the sensor that controls the speed on the treadmill. This means there could be a problem with the speed sensor. You may need to have a technician check the voltages on the power board and controller.
Nov 27, 2010 | HEALTHRIDER Exercise & Fitness
Canon DR-5020 Error Code E21
Just saw your problem! 'E21' refers to Document Board Motor Problem' Check if there is any loose contact and if required replace motor.
S. Mohan, Chennai, India
Jan 08, 2009 | Office Equipment & Supplies
Washing Machines Logo
15 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
