Question about Brother HL 2270DW Laser Printer
Can't print solid error light - Brother HL 2270DW Laser Printer
My printer is intermec PF8T i have i SAP program to print patient information but it cannot print the error is orange ligths was the error.
There are a few things to figure out here from a SAP basis administrator perspective these steps are common. Also I am just trying to help and with SAP there could be multiple solutions. Good luck.
Check SAP MarketPlace for SAP note: 1557674
Here are the steps taken from the SAP Community Network which might help. I would suggest reading the entire link as its informative. http://scn.sap.com/thread/1975158
Step:
run SPAD
to create an output device, choose Output Devices on the Devices/Server Tab
click on Display now you will be in Spool Administration window
click on Change button then Create tab will be appear, now you have to put the following information.
Under DeviceAttributees
put the Output Device name with shortname
Device Type: SAPWIN
Device class: Standards printer
you can put Model/Location/Message as per concern.
Under Access Method
Access Method: G
Host Printer: __default
save
for more information about
Device Type
http://help.sap.com/saphelp_nwmobile711/helpdata/en/d9/4a910f51ea11d189570000e829fbbd/content.htm
Access Method
http://help.sap.com/saphelp_nw70/helpdata/en/4f/9c033cff903105e10000000a114084/content.htm
(1) Choose "S: Print Using SAP Protocol" if a print server with SAPlpd or SAPsprint is used to print barcodes.
(2) Choose "F: Printing on Frontend Computer" if SAPlpd and SAP GUI are used together to print barcodes, SAP GUI sends print job to SAPlpd, SAPlpd is started automatically and forwards the print data stream to the Windows print manager.
(3) Choose "G: Frontend Printing with Control Tech", only SAP GUI is involved in printing barcodes, SAPlpd is not used.
Here are the Intermec drivers:
http://www.intermec.com/support/downloads/index.aspx
Understanding the LED Indicators
LED Meaning
Green (blinking) Auto-Sensing mode
Green (blinking) Downloading font, form, or graphic
Green (solid) Dump mode
Green (solid) Ready mode
Green (solid) Print mode
Orange (solid) Boot mode
Red (blinking) Media jam, overheated print head or stepper
motor
Red (blinking) Downloading firmware
Red (solid) Error mode
Good luck
Dec 27, 2013 | Intermec Office Equipment & Supplies
I have light in this ( !) what that is mean?
If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
Jun 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
My r230 is having this trouble: the two red lights are blinking.
If the Ink Out light flashes, the printer is getting low on ink; if it is on solid, the printer is completely out of ink and you need to replace the cartridge; if it is flashing rapidly, the printer detected a print head unit or ink cartridge installation error. If the Paper Out light is on solid, you need to install paper in the printer; if it is flashing, the printer detected a paper jam. When both the Ink Out and Paper Out lights are on solid, the printer thinks that there is a carriage error; if both lights are flashing, there is a fatal error and the printer will need to be sent in for service Source(s): http://www.epson.com/cgi-bin/Store/suppo...
Mar 06, 2011 | Epson STYLUS R230 InkJet Photo Printer
My tsp600 receipt printer will not print and the error light is on.
Dear Oasis Pools,
Please advise if the error light is flashing or solid. Also, perform a self test by turning the printer OFF, hold the feed button down, then turn the printer ON at the same time. A self test should print out. Did this print?
Regards,
Star Customer Support
For further assistance, please contact our Support Team at 800-782-7636 Option 2 for Tech Support or support@starmicronics.com
Feb 13, 2011 | Star Micronics TSP600 Thermal Printer
The arrow light wont stop flashing
this is common issue when paper jam or errors in printing queue,, check for any paper stuck inside (open up the back bay) delete the printing queue, power off printer restart the computer ! you should get solid green light
Dec 15, 2010 | HP Deskjet D4260 Printer
Epson r230
Nov 02, 2009 | Office Equipment & Supplies
Brother Printer HL 5250DN
A solid red STATUS light with a solid yellow TONER light indicates toner out...replace according to pg. 63 in the manual.
It can also indicate a cartridge position error. Take the DRUM UNIT out of the machine and re-install.
A solid red STATUS light only means:
Front cover open
Fuser cover open
Dust on drum
Too many trays
Buffer error
Print overrun
Memory full
Download full
Font full
See pg.48 ofthe manual.
Oct 02, 2009 | Sport & Outdoor - Others
Dell 1700n error light after print job.
double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
May 11, 2009 | Dell 1700n Laser Printer
One label prints, then red light comes on. We
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
Red light error :
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
Here is a trouble shooting guide:
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
PRINTER WILL NOT PRINT
1. make sure there are no error lights in the printer & you have a solid green power light
2. if you have a green power light, try reinstalling the driver
3. if the printer has error lights, check inks or paper obstructions
Jul 30, 2008 | Lexmark Office Equipment & Supplies
Brother HL 2270DW Laser Printer Logo
19 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
