Question about Epson Stylus Photo PX810FW Multifunction fax / copier / printer /
A Printer error has occurred. Turn power off and then on again. For details, see your documentation .
I finished nozzle cleaning and then ask for printing check to see if all ink colors are flowing. I did initial printing and it printed blank page. That was why I did nozzle cleaning.
  • 390 Answers
SOURCE: Blank pages from printer
Ahhh We love printers don't we??? Not!!! How did you clean the nozzles. Did you use the printers own maintenance system or did you do it manually. The printer can never clean them as well as you can manually, and this is probably 90% of the cause of blank pages. Clean rollers too while you are at it. Use a proper cleaning solution, and cotton buds, and clean where the cartridges go in, and the heads too. The next possibility is that the printer is set to pause, or print offline, go to your print settings, scroll down to properties and make sure thes two items are not checked. If so, unckeck them. Lastly, the drivers itself could be corrupted, and may need to download new updated drivers from epson website. Good luck
Posted on Aug 30, 2007
Basti
  • 1447 Answers
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Posted on Jun 17, 2008
0mutant
  • 18 Answers
SOURCE: color ink not printing
Ahhrgh! Don't use windex. It contains additives that can harm the printer head.
I suggested this site in another post and it could help you.
Posted on Sep 13, 2008
SOURCE: CX6600 Epson - prints blank pages
If the Nozzle Check Pattern page prints correctly and completely, the problem may lie within your software settings, the interface cable, or your computer.
To remove and install only the Printer Driver for your CX6600, please perform the following steps:
Driver Removal
1. Go to START then SETTINGS and click on CONTROL PANEL ( START and CONTROL PANEL in Win XP) and double-click ADD/REMOVE PROGRAMS.
2. To remove the printer portion select EPSON PRINTER SOFTWARE and click on REMOVE. Ensure the correct printer model is selected on the uninstall utility.
3. Click OK and follow the prompts. If asked to confirm removal of any personal settings or shared files, click YES or OK.
4. Once the components are removed, power off your unit and disconnect the USB cable.
Installation
1. Go to http://support.epson.com
2. Under Welcome to Epson Support click on ALL-IN-ONES and select FLATBED and then your Stylus model name. Under the Drivers & Downloads section select WINDOWS.
3. Download the most current driver for your printer and operating system.
4. Follow prompts through survey and license agreement and downloading will begin. When prompted, choose to SAVE this file; SAVE it to your desktop so it is easy to find.
5. Once download is complete, close your internet browser. To install simply double-click the file you downloaded and follow the prompts.
6. Do not reconnect the unit until the point in the printer driver installation where you are prompted to check that the unit is on and connected to the computer. Installation should complete automatically.
Posted on Oct 25, 2008
  • 31 Answers
SOURCE: My magenta ink will not print out. All other
Depending on the age of the printer and how often it is used it could be a dead piezo element in the magenta head or some dirt that is trapped in the feed mechanism to the head.That's why i never use refilled or poor quality substitute cartridges. Some Epson printers lasts for ages but unfortunately due to the head being permanent on all epson inkjets the only way out is for the replacement of the heads or a new printer. You could also try the magenta cartridge on another same model epson if you have access to one to see if the cartridge is perhaps a dud. Or alternatively purchase another cartdridge and check it out.
Posted on Aug 01, 2009
Error: printer error. turn off then on again. for details, see your documentation.
Hi I have a similar problem with Epson px660, it does not complete the self test after powering on then it flashes all lights with a printer error of fatal code 0x71, can you assist me kindly.
Best regards
Mar 13, 2015 | Office Equipment & Supplies
Epson TX720wd printer error thurn power off and then on again for detail see your documention
turn on of and then on again for details see your documentation - epson tx720wd printer
Jun 30, 2012 | Epson CX8400 All-In-One InkJet Printer
I have a code error Oxc18a0001 Ink System Failure, HP Photosmart C7280 All-in-One
There are several issues that can cause an Ink System Failure for an inkjet.
First try to reset the printer. With the printer on, unplug the power cord from the printer. Then unplug the power cord from the wall outlet. (If you are using a USB connection, also unplug the data cable from both the computer and the printer.) Wait at least 15 seconds and then plug the power cord back into the wall outlet and then the printer. Turn on the printer if it doesn't turn on automatically.
If the error persists, then clean the printhead. Have bottled or distilled water and lint-free clothes available (coffee filters will work). Note: you should plan on working quickly; the cartridges should not be out of the printer for more than 30 minutes. With the printer on, open the cartridge access door. Wait until the cartridge carrier comes to a stop. Then remove the ink cartridges, then lift the latch handle on the right of the print head. Lift the printhead straight up. Next dampen a lint free cloth (wring out the excess water). Wipe the electrical contacts from bottom to top (do not touch the nozzles) until the area is clean of dried ink. With another damp cloth, wipe the edge between the nozzles and the electrical contacts. With another cloth, wipe the two ramps on the sides of the print head working away from the nozzles. Dry all of these areas with a clean cloth (undampened). Next dampen another cloth and wipe the contacts inside the printer (work from top to bottom). Again dry the contacts. Then put the printhead back into the printer and lower the latch handle. Replace the ink cartridges and close the access door. Then reset the printer again if the error persists.
If the error continues, either the printhead needs to be replaced or the printer needs service. Unfortunately, a replacement printhead is not returnable if it does not solve the problem.
For pictures and details see the HP support site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=en&cc=us&product=3204785#N998 .
I hope this helps.
May 01, 2011 | HP Photosmart C7180 All-In-One InkJet...
Printer prints out blank pages
Follow these steps:
1. Load a few sheets of plain paper in the sheet feeder.
Turn off your printer.
Hold down the paper button as you press the power button to turn the printer back on. Hold down both buttons until the power light begins to flash, then release the buttons.
The printer prints its test page, which includes a nozzle check. Does the paper print out without any gaps or with gaps? If there are do this:
2. Load a few sheets of plain paper in the sheet feeder.
Make sure the printer is on and the ink light is off.
Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Head Cleaning.
Follow the on-screen instructions to start the cleaning cycle, which lasts about 1 minute. The power light flashes throughout the cleaning cycle and stays on green when the cycle is finished.
Caution:
Never turn off the printer during a cleaning cycle or you may damage it.
When the power light stops flashing and remains on, you can check to see if the nozzles are clean. Click Print Nozzle Check Pattern and click Print. Check the printed nozzle check pattern to see if there are gaps in the lines.
If there are no gaps, click Finish.
If there are gaps or the pattern is faint, click Clean to clean the print head again.
You may need to clean the print head up to 4 times. You can also turn off the printer and wait at least 6 hours. Then try printing again.
If this doesn't work then double check that you have the toner cartridges in correctly. If you do then your print head is broken and/or burned out and it's best to just replace the printer. Fixing it would cost more than the printer itself
Jan 17, 2011 | Brother MFC 420CN All-In-One InkJet...
After unpackaing the printer removing all tbas and seals installing ink i power on the printer to get the following : A printer error has occured. Turn power off and thne on again. For details see your...
Have you made sure the inks are installed flush and clicked in? Then is it doing a self check? if not then it's a master fault and you should take it back.
Sep 06, 2010 | Computers & Internet
HP Photosmart C5380 All-in-One. Ink system Failure. Oxc19a0023 My computer has Windows XP and IS is Internet Explorer.
The first step is to try resetting the printer. Turn the unit off, unplug the power cord and wait 30 seconds before reconnecting the power. Turn on the printer. If you still have the error message, you may need to clean the print head. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=au&lang=en&product=3560275&docname=c01458034 has the details.
Remove all of the cartridges, lift the handle on the carriage until it stops. Lift the print head straight up. Once the print head is out, you need several lint-free cloths and distilled or bottled water. With a damp cloth, wipe the electrical contacts from bottom to top (do not go past the edge). Then wipe the edge between the ink nozzles and the electrical contacts - wipe away from the nozzles. Wipe the ramps on either side. Dry all three areas.
With a new damp cloth, wipe the contacts inside the printer from top to bottom until no ink remains on the contacts. Dry this area.
Reinstall the print head and lower the latch carefully. Reinstall the ink cartridges making sure that they snap into place.
Check if the error message repeats. If it does, try resetting the printer (power cord unplugging cycle). If you still get the error, the print head may need to be replaced. If a new print head is in and the error occurs, talk to HP support if the printer is under warranty. You'll have to decide if these last two steps are worthwhile if the printer is out of warranty.
I hope this helps.
Apr 24, 2010 | Office Equipment & Supplies
Printer mechnical error
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
There is a paper jam Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the Power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
Print error occurred. Please see documentation.
Check status monitor at your OS. Find RX620 adjusment program at indoreset.blogspot.com. Check status from the adjusment program. It is more detail. General error at display or OS status monitor can mean many posibilities error.
Jun 30, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson Stylus Photo PX810FW Multifunction fax / copier / printer / Logo
111 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
