Brother IntelliFax-2820 Plain Paper Laser Fax
Problem for Brother IntelliFax-2820 Plain Paper Laser Fax
I want to replace the toner unit.
By gfpmus on Oct 10, 2007
I have been asked to make a unit work. I only have a general operation document, which tells me nothing. I need to remove the drum unit, but it seems to be stuck. I have found what looks like a release lever, but it won't move. Can you help me?
Best Solution
posted on Oct 17, 2007
Very Helpful)
Soulvisitor
Rank: Guru  Brother Expert
Rating: 88%, 2376 votes
Release lever is for releasing TONER out of drum not for releasing drum... drum should pull out slightly up and forward with toner attached fully. If it is stuck then their may check if a  sheet of a4 is stuck and holding it in.
Was this helpful?
Yes
No
Popular Solutions for Brother IntelliFax-2820 Plain
Questions and Unsolved Problems for Brother IntelliFax-2820 Plain
Do you recommend Brother IntelliFax-2820 Plain Paper Laser Fax?
Answer
Answer
can you tell me how to change the time on the fax
Answer
how can you forward faxes coming in to another fax line?
Answer
brother intellifax 1250 will not copy or start to send - the copy stop and start buttons are dead
Answer
I need to delete the memory in a MFC-8500 fax machine so it can be trashed
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Fax Machine Experts
Top Copier & Fax Repairmen
in , TX
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
