Question about Canon PIXMA MG5420 Inkjet Photo All-in-One
Pixma MG7120 error 5101
Trying to set up a new printer. error message that there is protective material that needs to be removed, but it has been, and I continue to get the error code.
  • 52 Answers
SOURCE: Waste ink absorber
hi i am a certiffied Canon repair tech for this model. this is true this will reset the error but doing so without replacing the waste asorber pad in the bottom of the machine will cause your machine to backup waste ink into the the printing area of the machine and will start smuging ink on the page. the waste absorber is fairly cheap but the labor varies from shop to shop. there are independent Canon repair shops throughout the world. you can call 1-800-ok- canon or look on the canon website. hope this help to clairify.
Posted on Jan 05, 2008
Joed911
  • 4338 Answers
SOURCE: Ink absorber is full.
Try this:
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 01, 2009
  • 489 Answers
SOURCE: Error code 5800 for Pixma MP130. When try to get
you can try this:
Turn on the printer (MP130) and do the following:
1. Press MENU SCAN COPY SCAN to enter service mode
2. Use > to go to NVRAM ACCESS
3. Set ABS-M LEVEL to 0
4. Set ABS-P LEVEL to 0
5. Press STOP to exit
Done, hope it work.
Posted on May 30, 2009
komguy
  • 2306 Answers
SOURCE: error code 5100 on canon pixma mx700
5100 says the carriage is not moving all the way across the paper path. There could be grease or ink on the encoder strip, the clear strip behind the carriage. Or a small paper scrap inside stopping the carriage.
Posted on Aug 10, 2009
manuel-d
  • 5 Answers
SOURCE: Canon Pixma ip1900 Printer wont print
i think you need a canon resetter just download it and it will fix your problem. gud luck ellyhill
Posted on Nov 16, 2009
How do you edit a jpeg file to print entirely, on a Canon Pixma MG7120 printer? Tried printing a file, but, no all picture was printed.
you shouldn't need to edit the file, it's far more likely there are settings in your printer configuration (most likely your computers print setup) that need to be corrected
Mar 02, 2017 | Canon Office Equipment & Supplies
I have many numerous issues how do i empty waste hold?
Is this the inkjet waste ink holder? If so it is the death knell for the printer and is a hint from the maker that you have had it too long. There is no fix, time for a new one, which you will find are greatly improved as regards wireless, colour, quality and speed.
I can recommend the Canon MG7120.
PIXMA MG7120 Canon Canada Inc
Jan 06, 2016 | Office Equipment & Supplies
My Printer mg7120 Black not On for nothing.
Check the cartridges. Remove the cartridges and re insert it. sometimes bad contacts can causes such problems.
for more details check the link bellow
http://electro-medical.blogspot.com/
Dec 26, 2015 | Canon PIXMA MG7120 Wireless Inkjet Photo...
How can I scan and fax 84 page document from the PIXMA mg7120?
that is correct, use the automatic feeder tray, but i am not sure if that machine can scan and fax all the 84 page continuously
Feb 12, 2015 | Canon PIXMA MG7120 Inkjet Multifunction...
I have a canon pixma MG7120 printer and it keeps saying theres is no paper in the cassette when there is.
You might find there are two paper paths or cassettes. In which case the machine may be trying to take paper from the OTHER one. If that isn't the problem, then the paper sensor arm has been dislodged and needs to be found and repositioned
Sep 20, 2014 | Canon PIXMA MG7120 Wireless Color...
What should I do to fix my canon mg7120 printer when I get the message "printer not responding"?
check that the printer is "on", and that it's actually connected. Change USB cable for another one, plug into a different USB socket on computer. If no help, try on another computer.
Sep 02, 2014 | Canon PIXMA MG7120 Wireless Color...
Our new Canon PIXMA MX870 is showin a 6A80 error before step 3 of the setup. The printer cartridge holder won't move into the loading position (to the right), and we cannot clear the error (tried pressing...
Remove the Protective Material Before turning on the machine, remove all the orange tapes and protective sheets. If the machine is already on, press the ON button to turn off the machine before removing the packing / shipping materials.
Let me know if this corrects the problem. Thanks.
May 03, 2011 | Canon PIXMA MX870 Wireless Office...
I am just setting up my new MX350 All-in-one printer and when I have plugged it in and hit the On button, the screen displays a printer error with the number 5100 on top. What do I do?
error 5100 means that you have not removed all the packing tape and protective plastic. The manual is a but confusing. You must open the printer as if you were isntalling the print cartridges and remove the packing material from inside the printer.
Aug 26, 2010 | Canon PIXMA MX350 Wireless All-in-One...
I have a new pixma ip5200 inkjet,never used and it just comes up
Dear hemi1223,
It seems that the printer has problem with feeding mechanism. Here are possibilities: some materials block paper end so it does not reach paper cam sensor, paper feed sensor error, broken paper left inside printer and sheet feeder part broken. I suggest you to take your printer to the nearest service center.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 22, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Remove protective material on right side - can't remove it
In all likely hood you just ruined the printer. Take it back to the store and tell them you bought it that way. ;)
Generally all protective objects for removal are colored neon, obviously labeled as such, or are simply tape. The protective material they indicated is most likely either a piece of tape across the print head or a plastic plug, which may or may not have even been there depending on if the printer was a return, it fell loose, etc. before you got it home or took it out of the box.
Jul 31, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MG5420 Inkjet Photo All-in-One Logo
181 people viewed this question
old marine
old marine
