Question about Samsung Sde-3003n 4 Channel Dvr System, 4 Ir Cameras, 1tb Hdd Sde-3003, Warranty
Drive Remove - Samsung Sde-3003n 4 Channel Dvr System, 4 Ir Cameras, 1tb Hdd Sde-3003, Warranty
How to remove hard drive from fujitsu n6000
On the bottom of your Fujitsu N6000 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Fujitsu N6000 hard drive caddy, or simply remove the door.
4. Once the Fujitsu N6000 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Fujitsu N6000 hard drive.
Good Luck
Aug 31, 2014 | Computers & Internet
Hard drive replace
Remove the power cord, remove the battery, turn the laptop over and remove the screws from the cover that houses the hard drive. The icon where the hard drive is located will be 3 circular discs. Once you remove the cover, there might be screws that hold the drive in the bay so remove them. Carefully lift the drive out then remove the screws from around the drive that holds it in the caddy.
If the hard drive is not on the bottom of the laptop, then it will be under the keyboard or palmrest.
May 09, 2012 | Computers & Internet
Remove hard drive on Dell pp10s
Remove the power cord, remove the battery, turn the laptop over and remove the screws from the cover that houses the hard drive. Most times there will be an icon of circular discs where the drive is located. Once the drive is exposed, remove any screws if any that hold it in place then carefully take the drive out. You will probably have to remove screws from the hard drive caddy once you remove the drive from the computer.
If the drive is not on the bottom then it will be located under the keyboard or palmrest.
May 09, 2012 | Dell Computers & Internet
Remove A: drive compaq presario sr1055cl
Remove the side panels on your desktop computer. The floppy drive will be attached to the drive bay with 4 screws (2 on each side of the floppy drive) or by a plastic slide clips. After removing the screws, remove the power cable and the data cable from the back of the floppy drive and then you can slide the floppy drive either to the back or the front of the drive bay to remove the floppy drive from the desktop case.
Feb 08, 2012 | Compaq Presario sr1055cl PC Desktop
Aspire one can not detecthard drive
Repair laptop hard drive is not detected
Solution 1
1. Open the hard drive cover (remove two screws)
2. Remove the hard drive screws, then slide the hard drive (see the arrows)
3. Wait 15 minutes, then plug the hard drive
4. Turn on the laptop.
Solution 2
1. Remove the hard drive
2. Clean the gold layer with a pencil eraser
3. Plug the hard drive, then turn on your laptop
Solution 3
2. Plug jumper on the hard drive
Solution 4
1. Remove the hard drive, plug the external cable.
2. Connect the hard drive to another computer, with USB connection
3. If the hard drive can be detected, eject the hard drive
4. Plug the hard drive to the laptop, then turn on
Intended to make the hard drive can work with the help of another computer
Solution 5
1. Remove the laptop hard drive
2. Plug the laptop hard drive to my PC.
SATA1 - PC hard drive
SATA2 - Laptop hard drive
3. Boot the computer from a PC hard drive
The purpose of using a PC computer main-board as drivers of the laptop hard drive.
I hope this information helps. Thank you for using FixYa!
Oct 15, 2011 | Acer Aspire One PC Notebook
REAR FAN FAILURE DELL OPTIPLEX 755
This is the rear fan
Replacing a Hard Drive Fan
  1. Follow the procedures in Before You Begin.
  2. Remove the computer cover (see Removing the Computer Cover).
  3. Remove the hard drive (see Removing a Hard Drive).
  4. Turn the hard drive upside down, so that the hard drive fan is visible in the bottom of the drive bracket.
  5. To remove the hard drive fan:
    1. Lift the release tab on the back panel of the fan.
    1. Rotate the fan in the opposite direction from that indicated by the arrow on the back panel of the fan.
    2. Lift to remove the fan and its back panel from the hard drive bracket.
klamma16.jpgReplacing a Hard Drive Fan
  1. Follow the instructions in Before You Begin.
  2. Remove the hard drive (see Hard Drive).
  3. Remove the hard drive fan:
    1. Remove the screw that secures the fan release tab to the hard drive bracket.
    1. Press down on the fan release tab, and then slide the fan towards the front of the computer so that its side tabs are free of the corresponding slots in the hard drive bracket.
    2. Lift to remove the fan from the hard drive bracket.
    3. Unplug the fan.
May 30, 2011 | Dell Optiplex 755 Ultra Small Form Factor...
Where is the location & how to remove the hard drive for toshiba satelite P15-S470
The hard drive is located under the CD/DVD drive. Before you start taking apart the laptop, remove the battery and unplug the AC power.
1. You have to remove the CD/DVD drive. Turn the laptop over. Remove one screw right above the dive and slide the drive out of the laptop.
2. When the CD/DVD drive is removed, you'll see a metal plate. The metal plate is secured by 4 screws. Remove them and lift up the plate from the bay. The hard drive is located right under the plate.
3. After you remove the plate, you'll see the hard drive. The hard drive also secured by 4 screws. Remove the screws, slide the hard dire to disconnect it from the connector on the moterboard and lift it up.
4. You have to transfer the brackets from the old hard drive to a new hard drive. Also, if there is a foil shielding around the old hard drive, you'll have to transfer it to a new hard drive too.
Below is website with a picture guide on how to remove the hard drive>>>>
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P10/remove-hard-drive.htm
Regards.
Apr 21, 2011 | Toshiba Satellite P15-S470...
Location of compaq 1692 hard drive and how to remove to retrieve data?
Here is the maintenance and repair manual....
http://www.elhvb.com/mobokive/edwin/laptops/Compaq/Compaq%20Presario/1683-1694.pdf
be sure to save a copy for yourself.....
1. Prepare the
computer for
disassembly.
2. Remove the
palmrest cover
with touch pad.
3. Remove the
keyboard.
4. Remove two
screws from the
hard drive
mounting
bracket and lift
out the hard
drive with drive
mounting
bracket
attached.
5. Disconnect the
hard drive
data cable
from the hard
drive and
remove from
the chassis.
6. Remove four
screws from
the hard
drive
mounting
bracket.
To replace the hard
drive and hard drive
mounting bracket,
reverse the
previous
procedures.
Oct 24, 2009 | Compaq (17XL570) PC Notebook
How to change engine belts on a jaguar x-type 2003 3.0
To Remove BELTS : Drive Belt :
Disconnect battery ground cable
Remove wheel and tire
Detach accessory drive belt
detention drive belt
detach accessory drive belt
Remove accessory drive belt
slacken the tensioner
remove accessory belt drive
Install in reverse order
WATER PUMP BELT : Remove battery tray
Remove water pump belt
De-tension water pump belt
Installation in reverse
Hope this is helpfull
Jul 11, 2009 | 2003 Jaguar X-Type
Need to remove cd drive
if you want to remove cd drive means.....first you want to remove two wires from the cd drive.....you want to remove power cable and then data cable that is connecting to motherboard.........then you can easily remove the cd drive.....
Sep 20, 2008 | Sony Computers & Internet
Samsung Sde-3003n 4 Channel Dvr System, 4 Ir Cameras, 1tb Hdd Sde-3003, Warranty Logo
20 people viewed this question
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
