Question about Gigabyte GA-8I915PL-G Motherboard
I need sound card for gaigabyte ga-8i915pl-g for windows 7
3 Suggested Answers
map9966
  • 2351 Answers
SOURCE: Motherboard: i need ga-8i865gme-775-rh-driver for windows 7...
Try this windows 7 link; http://driver-pro.com/related/english/windows-7-drivers/?a=17743&gclid=CJLvoozNs54CFYRC5god1UbDdA&hit=1&l=45
This site works well.
Mike
Posted on May 18, 2010
bronk50
  • 27725 Answers
SOURCE: where Can I found driver
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Posted on Feb 22, 2011
NEED GA-31M-S2C SOUND DRI
Hi, you can download sound driver for gigabyte motherboard GA-31M-S2C HERE.
This driver support Windows® XP, Windows® XP 64bit, Windows Vista x86 (32-bit), Windows Vista x64 (64-bit), Windows 7 32bit, Windows 7 64bit.
Good luck, Kobac
May 26, 2011 | Computers & Internet
Can i install 1 tb hard drive
Your board has (4) Serial ATA (SATA) connectors so you can install an SATA hard drive of any size you want. Make sure you are running at least Windows XP SP 3 because earlier versions had trouble recognizing large hard drives. Also make sure your power supply has connectors for SATA drives. If not you can find 4 pin MOLEX to 15 pin SATA power converter cables on Tigerdirect.com
Oct 16, 2010 | Gigabyte GA-8I915PL-G Motherboard
I want ga-8i915- lge motherboard driver
the driver for GA-8i915-LGE is same with GA-8I915G-MF (Best solution so far)
Aug 08, 2010 | Gigabyte GA-8I915PL-G Motherboard
Mobo does not see the second dimm pc will not boot 4 long beeps
hi, try to change the ram of dimm see if it work or tray ram one buy one and if a ram does't work try to replace ;)
Jan 17, 2010 | Gigabyte GA-8I915PL-G Motherboard
I have no sound from my ga-k8nsc-939 motherboard after installing windows 2003 server.
Hi friend,
You need to install sound card drivers for sound.you will find out mother board CD so update your sound card drives then you can hear sound....
With Regards
Jan 01, 2010 | Gigabyte GA-K8NSC-939 Motherboard
My computer is only recongising one ram slot
may be your ram frequency is conflicting. so it is not run with each other.
Feb 07, 2009 | Gigabyte GA-8I915PL-G Motherboard
GA-8I915PL-G PCIe x1 Slot Issues
try switching the BIOS setting from AUTO select to manual and force the setting there
May 18, 2007 | Gigabyte GA-8I915PL-G Motherboard
Gigabyte GA-8I915PL-G Motherboard Logo
22 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
