Question about Fisher and Paykel Ovens
Oven heats up slow
OB 76 top oven takes too long to heat up 45mins to 175 bottom oven ok
SOURCE: Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Posted on Jan 06, 2008
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
SOURCE: Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
Posted on May 29, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
    Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
    Posted on Jul 23, 2009
    Blodget zephaire G takes 2 hours to reach temp.
    It hard to tell, please let me know what did you see and hear when turn on oven...
    Jan 14, 2014 | Blodgett (ZEPHAIREG-DOUB) Double Oven
    Whirlpool akz161 top oven. The lower heat element is not working how do l access this as l need to fix it myself
    open door if you can see screws at element ends remove them and change or you will have to do it from the rear
    Nov 16, 2013 | Ovens
    Oven only goes to 175 degrees
    If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
    Oven Problems Electric Oven is Heating Slowly or Poorly
    heatman101
    Dec 30, 2010 | Frigidaire GLEB27S7A Electric Single Oven
    Top oven does not heat-although bottom oven is ok.
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Jul 29, 2010 | Whirlpool GBD277PD Electric Double Oven
    GE JTP56 double oven controls OK top OK bottom no heat
    have you inserted the business card as described in the solutions?
    Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
    Neff U1721 bottom oven not heating fan & light are ok
    Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
    Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
    Heating
    i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
    Mar 25, 2008 | Maytag CWE5800A Electric Double Oven
    Sep 18, 2007 | Ovens
    Ovens Logo
    27 people viewed this question
    Top Fisher and Paykel Ovens Experts
    Dan Webster
    Dan Webster
    Flipper
    Level 1 Expert
     Fix Your Board
    Fix Your Board
    Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
