Question about Kenmore Elite 45986 Front Load Washer
Cleaning cycle When I follow the instructions in the manual to start the self cleaning cycle - rinse and spin, low speed, warm/cold, 2nd rinse, push signal button 4 times - nothing happens. Any ideas?
  • 185 Answers
Does it tell you to count in seconds if it does count like 1one thousands 2one thousands and so forth
Posted on Mar 27, 2008
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Self cleaning button sequence want start
you need to see in the bottom of your washer or take the back panel and some of this washers have a reset button, try due that, make sure is unpluged while you due this, clean all the contacts inside and check all the wires make sure they okay
Oct 17, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Lost manuel an forgot how to run cleaning mode on duet front load model#ghw9150pw4
1) turn to rinse/spin option on dial
2) select low spin speed button
3) select warm/cold temp
4) set end of cycle signal to softer
(you will notice all the lights light up in a row, that is how I remember)
5) Press the extra rince button 4 times within 5 seconds.
The bleach you add is either 1 cup if you haven't done this in a while and then 1/3 monthly
Hope that helps!
Jan 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How much bleach do you add during cleaning cycle?
If the model number is correct, to run a "Clean" cycle on this model washer you need to follow these steps:
1. Make sure wash tub is empty and close the door.
2. Open the dispenser drawer and remove the plastic divider in the MAIN DETERGENT compartment.
3. Select the following options:
a. Select the POWER button.
b. Select RINSE/SPIN.
d. Select WARM/COLD water temperature.
f. Press EXTRA RINSE button 4 times within 5 seconds and the
will begin.
4. The washer will run a short sensing cycle for about 3 minutes.
5. The washer will beep 4 times and a code will appear on the front panel display.
a. If "Ab" (Add Bleach) appears - skip to step 6.
b. If "Rl" (Remove Load) appears - the door will unlock and you
need to double check the wash tub for any items. Close the
door when complete and press the START button.
6. Add bleach. If this is the first time running the clean cycle add ONE CUP of bleach to the detergent compartment of the dispenser drawer. If this is a monthly routine, add only 1/3 CUP of bleach.
These instructions are listed on page 18 of your owner's manual. If you no longer have a manual, yo can obtain a FREE copy at Just type in your model number under their "Manuals" link and you will find it listed in .pdf (Adobe) format that you can download or print for free.
If you have questions, please post back and let me know. I hope this helps you.
Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Capresso s8 weak coffee
You should probably run a cleaning cycle with a cleaning tablet (the one you drop into the ground coffee shoot, not a decalcifying tab).
This will clean out all the insides where coffee particles and oil can accumulate.
The machine will ask you to run a cleaning cycle after a certain number of cups brewed. But you can also manually start it.
(this is copied from the manual)
You can run a tablet cleaning cycle at anytime even if
the machine does not prompt you,
• READY. Push and hold the Rinse button until display shows
RINSE. The Dial illuminates.
• Turn the Dial until display shows CLEANING. Push the Dial.
Display shows EMPTY DRAWER.
(Follow the rest of instructions for regular cleaning cycle)
Jan 16, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Need to initiate cleaning cycle
to enter the cleaning cycle:
Select the RINSE & SPIN button.
Select Low SPIN SPEED'
Select the 2ND RINSE Option.
Push the END of CYCLE SIGNAL button 4 times within 5 seconds to start cycle
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Self cleaning oven instructions
you can google it or just push the clean button and it will most likely default to 3 hours and all you have to do is push start and after it is done wipe out the ashes with warm soapy water DO NOT USE OVEN CLEANER as this will destroy the finish of the self clean cavity
Nov 12, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
LF Error Code
How is the water filling? Slower than it should?LF (long fill) Start by removing the hot & cold hoses off the back of washer ,now look inside the valve for clogged screens,if they are clogged ,clean them.If problem continues replace the water valve.
May 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
268 people viewed this question
Sal De
 Brian Main
Brian Main
