SOURCE: Vertical Deflection
If you can still read your serial number you can contact the manufacturer to get the details on this product? EVERY manufacture requires to keep this information on file for years past to current. I know since I've worked for a projector manufacturer. Otherwise, I also found this PDF diagram which might help you out with the number you need: http://www.e-daewoo.com/products/owners_manual/CN115N-010_7.pdf Good luck with your problems & let me know if that helps you out or not.
SOURCE: Kv-36xbr800
Hiii...
My version is :
For safety reason you should replaced them ( Horizontal ic,Vertical ic, Deflection ic) and olso all the big capasitor nearest the ic....that's my version....if you have big budget for it....he..he....
Thank's
[Vrya]
SOURCE: LG vertical failiure vertical line at the bottom of the crt
replace the vertical driver ic and the proccesor ic
SOURCE: 2 vertical bars on right half-side of screen
you are in luck my friend! i just performed a fix on a gateway plasma that has LG boards inside. It is exactly what you are talking about. Go to the attached link and follow the thread carefully and read it all before starting. IT WILL WORK!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
SOURCE: Dear Sir: I have a Toshiba 27 tv vcr combo tv.
Hi.
Here IC specsheet:LA78041
Also replace the 100uf/35 volt cap on pin three of the IC and the two zener diodes connected to the IC. That is part of standard repair. If you don't replace the whole lot the IC may blow again.
Here the IC for sale. Cost is less than $5.
