Question about Belling 24 in. IDW602 Built-in Dishwasher
Idw604 won't clean - Belling 24 in. IDW602 Built-in Dishwasher
I have a belling IDW604 integrated dishwasher which is not heating the water
An open element will have voltage present and still not operate. Use an ohm meter to test it.
Dec 21, 2015 | Belling Dishwashers
Belling IDW604 wont heat water
Check heater for continuity, thermostat and control timer
May 09, 2012 | Belling 24 in. IDW603 Built-in Dishwasher
Belling idw604 not filling with water, any ideas??
If you can test the supply voltage to the inlet solenoid it may have failed, if it has voltage as required and it is not letting water in the solenoid it's self will be at fault.
Mar 12, 2012 | Dishwashers
E4 is displayed on my belling idw604 dishwasher and it won't operate
unplug machine. remove right hand side panel. check if water has collected in the bottom tray, if so soak up with cloth or kitchen roll until all water has been removed. switch on power and machine should have reser
Feb 07, 2011 | Belling Dishwashers
I have a belling dishwasher IDW604. I haven't used it in 3 months and now there is no power. It won't switch on. Why?
check your power cord usually under the sink also check all GFCI Outlets in your home for a possible trip
Mar 08, 2010 | Dishwashers
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Instruction book
need the manual for the belling idw604 dishwasher
Jul 04, 2007 | Belling 24 in. IDW602 Built-in Dishwasher
Belling 24 in. IDW602 Built-in Dishwasher Logo
20 people viewed this question
Top Belling Dishwashers Experts
Kamil Owsianiecki
Level 1 Expert
Jeff Hogancamp
Jeff Hogancamp
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
