Question about Samsung SCX5935FN Laser Printer
Door is open close it on samsung 5935fn - Samsung SCX5935FN Laser Printer
Samsung microwave turns on when open door
The switch assembly is somehow staying "closed" satisfying the interlock and enabling it to run.
Disassemble the unit, beware specially of the high voltage capacitor, if you aren't comfortable or competent, buy a new microwave. If you are mechanically inclined, disassemble the unit until the switch assembly is accessible; it will have the door latch attached to it.
The switch is either broken or something? exogenous is keeping it closed. It may have come loose due to the door slamming?.
It's a simple fix. I am certainl you will be successful.
May 04, 2017 | Samsung Microwave Ovens
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
Samsung scx-5935fn won't print with out id and password
in the security your admin has enabled the security feature.
It needs to be disabled.
Jan 30, 2013 | Samsung SCX5935FN Laser Printer
Samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Jun 22, 2012 | Samsung 24"" Dishwasher
Samsung Refrigerator opening door is very hard.
Very common problem, due to full power of magnetic gasket. It's my own experience but some other brand, the solution is:
Don't close the door roughly or even don't allow fast to close automatically. Close door gently. And take some talcum powder (face powder) rub nicely on door gasket all four sides. Repeat it at least once in a month, until when you can open door smoothly. Thanks, helpful?
Jan 27, 2011 | Samsung RB215LASH
Samsung sensor quick P801 can't close the door. The main front door can not be close easily. I take me 6 to 7 try to close it. Sometime I need to slap the door firmly. The Door seem to be close but just...
you should not be able to open or close the door with the washer ON. You must first shut off machine before closing the door, then turn the machine ON, this should lock the door closed. to open the door, you must shut the machine OFF, then the door should open easily. Follow the directions in the manual... you can Download the owners manual here, in your language of choice; Follow the link below. just copy and paste it into you browsers window.
http://www.usersmanualguide.com/samsung/washing_machine__drum_type/p801
Don't forget to rate the answer.
Jan 24, 2011 | Samsung Washing Machines
Samsung SCX5935FN Laser Printer Logo
81 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
