Question about Alpine Car Audio & Video
Alpine CDE 141 will not output to sub
When i plug a 3.5mm jack w/rca into the amp the sub thumps. when i try the rca from the head unit i get nothing. all wires are good and in phase, have tried two rca wires that are known good. any ideas?
  • patrick
    patrick Nov 24, 2013
    Ok so it is a fresh install of a known good amp, sub, and wires. amp gets power. sub gets power. it seems the input from the head unit is not working, because i can hook up a RCA cable directly to the amp and playing music from my phone and the sub thumps hard. when i run RCA cables from the head unit to the amp, I get almost no vibration from the sub. Equipment Alpine CED-141 Head unit, 2 pre outs. 3 days old. Memphis 500W PRX1500 Amp Memphis 12" sub.
    Top Expert:
  • Alpine Master
  • 34,153 Answers
Your description is not very clear but my guess is that the output from the RCA connector on the head unit (receiver) is low level and intended to be connected to an amplifier input. Apparently the 3.5 mm "jack" (plug) connects something to the RCA input of the amp and that works.
Posted on Nov 24, 2013
Testimonial: "well i have tried the RCA inputs on a pioneer and an alpine head unit, i just put the specs up of the alpine as that is what im trying to use. The RCA cable goes from the amp to the head unit."
IB4G2008
  • 3587 Answers
SOURCE: head unit connot find ipod
hmmm..does the Ipod that works, have same version as the one that does not?
Posted on Mar 10, 2008
hack124x768
  • 33 Answers
SOURCE: connect alpine 7874 to alpine powered sub
You need to run the RCA cables from the head unit to the sub for the audio signal, and possibly a turn on wire (the blue one on the back of the head unit), unless the sub has an automatic power feature.
The sub also needs power and ground wires attached, but those do not connect to the head unit. Power should be run directly from the battery with an inline fuse, and ground should go to the nearest good ground point (Trunk latch, seat bolt, etc).
Posted on Mar 28, 2009
SOURCE: Accessing aux port on Alpine CDE 9881
If you happen to have the tool which allows you to remove your head unit from the dash use it. If not go to crutchfield.com and get one it's useful for any audio enthusiast. Once you have the tool pull the head unit out on the back of the unit there is a cable that is black with a blue connector tip. This is what you plug your cable that you got from your audio dealer into. As for making the cable accesible you may have to drill a hole in your dash or run the wire around and out the glovebox which is also common and suggested for your particular car.
Posted on Jun 11, 2009
etirbynnor
  • 655 Answers
SOURCE: i am getting a DC error on my alpine cde-102 head
Hello christo12385,
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
Hope this helps.
Posted on Sep 25, 2009
  • 2427 Answers
SOURCE: how can i test my rca output jacks with a test
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Posted on Mar 12, 2010
Testimonial: "after hours of web search and pioneer support, u hit my problem right on the head. outstanding job,thx"
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
Alpine 9845 cde head unit car stereo i Cannot figure out how to access the Fader not the balance,altho i havent seen that function either. ive been to the alpine site and they dont even mention it. im sure...
Press the Rotary encoder (CDE-9845/CDE-9843
only) or press MODE (CDE-9841 only) repeatedly
to choose the desired mode.
Each press changes the modes as follows:
BASS → TREBLE → SUBWOOFER* → BALANCE → FADER
→ DEFEAT → VOLUME → BASS
BASS: -7 ~ +10
TREBLE: -7 ~ +7
Subwoofer : 0 ~ +15
Balance : L15 ~ R15
Fader : R15 ~ F15
Defeat : ON/OFF
Volume : 0 ~ 35
Feb 11, 2010 | Alpine CDE-9845 CD Player
Subwoofer for alpine cde-9843
In short, no.
The CDE-9843 cannot drive a sub of the type you mention without an amp, but you can fit a sub with it's own built-in amp.
As standard, the head unit has a basic in-built amp supplying 4 x 16w RMS at 4ohms but there is the facility via the unit's own menu to turn off the in built amp and use the output sockets as a pre-amp feed, but in reality if you want to drive an amp you'd be better off to start with a more highly specified head unit to begin with, even the next model up, the CDE-9845 is better suited as there are pre-outs for front and rear speakers.
User instructions are available from here.
If my reply has been of assistance then please return the favour by rating my answer.
Nov 09, 2009 | Alpine CDE-9841 CD Player
How do you hook up a subwoofer to Alpine CDE-7858
go into the menu of the radio make sure sub output turn on
Aug 28, 2009 | Alpine CDE-7858 CD Player
One rca jack for subwoofer (jvc kd-avx44)
I run this set up im runng a 1000 rms Alpine and 2 alpine type S and everys good
Jun 28, 2009 | JVC KD-AVX33 Car Video Player
How to hook up my rem amp wire to this player it does not have
If by saying amp outputs you are refering to the RCA jacks on back of the head unit (Left and Right RCA jacks usually labeled FRONT, REAR, SUB, etc...) then you do have options even if your head unit doesn't provide a SUB channel.  These RCA jacks/amp outputs carry the signal (music or whatever) at a lower voltage (and is typically more like DC voltage as there is a ground reference which is 0 volts and signal rides on the positive voltage), providing a cleaner signal to the amp which does all the work.  The wires behind the amp that you connect directly to the speakers is typically amplified by the head unit itself and is a much higher voltage level and varies from negative to positive ( AC voltage.).
You could use the other channels (FRONT or REAR) if available, (a specific SUB amp output cuts all the higher frequencies out, passing just the lower subwofer frequencies inside the head unit).
if you want to strive for a more efficient use of your sub, use a low-pass/SUBwoffer filter (a crossover) in between the Head unit and amp, thus providing the amp with subwoffer signal, (or if for some odd reason you have SPEAKER level sub connections you can use a line output converter which will let you run RCA to the amp.)
Hope this helps u understand why I couldn't just say get a new stereo nor could I just say use splitters on available amp outs.
Mar 05, 2009 | Lanzar SDBT75N Car DVD Player
Still no sub woofer output
SET THE CROSSOVER TO "L.P.F."POSITION AND SELECT THE LOWEST FREQUENCY AS THE CROSSOVER POINT.
[AN AMPLIFIER IS SUPPOSED TO "AMPLIFY"(TO INCREASE)ANY OUTPUT.]
TRY CHANGING THE POLARITY OF WIRES FROM AMPLIFIER TO SPEAKERS /SUBWOOFER.{it leads to cancellation of bass output.}
if u still have doubt contact me again.
May 26, 2008 | Alpine CDE-7856 CD Player
Alpine
If this occurs with the head unit plugged directly into the amp (no signal processors inline, you probably have open shields on the head unit.
To check the shield ground, disconnect all RCA cables from the head unit and measure the resistance between the RCA shield on the head unit and the case of the head unit. It should read ~0 ohms.
Dec 03, 2007 | Car Audio & Video
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Car Audio & Video Logo
64 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
