Question about Vehicle Parts & Accessories
Astrostart remote start
When I use the remote start, the check engine light comes on. Source of the problem is voltage lost to transmission solenoid.
moparownr
  • 667 Answers
SOURCE: TRANSMISSION PROBLEM
You have a shift solenoid problem, it will probably have to be replaced, it will require taking off the transmission oil pan (draining trans oil), I recommend that you leave this task to a repair shop, it is a little tricky to do and it is very important that the inside of the transmission stays very clean. I hope this helps you, please let me know
Posted on Jun 03, 2009
Molson02536
  • 3854 Answers
SOURCE: transmission solenoid malfunction check engine light on
Your going to have to bring it in to a transmission shop and sorry could not help you with any other recommendation with the lack of information to your car's year and engine size, or the DTC codes. Good luck and hope it's just a transmission line pressure solenoid that when bad.
Posted on Jul 29, 2009
  • 35 Answers
SOURCE: my automatic transmission solenoid is causing
Most transmission solenoids are located within the pan. If you replace the solenoids then it would be a good idea to change out the wiring harness that runs from the main transmission plug to the solenoids. Just lower the pan and drain it. Then, remove the one or two bolts that hold the solenoids in place. Replace the solenoids, wires, transmission filter and fluid at the same time (since you're already there). Make sure that you use a new pan gasket when you put the pan back on or it will leak fluid. Good Luck!
Posted on Nov 17, 2009
Testimonial: "very helpful"
  • 412 Answers
SOURCE: trouble with the transmission solenoid
USUALLY A SHIFT SOLENOID DTC IS REPAIRED BY REPLACING THE TRANS SOLENOID PACK ASSEMBLY..LOCATED ON OUTSIDE OF TRANSMISSION..YOU MUST BE CAREFUL WHEN CHANGING PACK..CLEAN ALL DIRT/DEBRIS FROM OUTSIDE OF PACK..YOU DON'T WANT ANY DIRT TO ENTER TRANSMISSION..SOLENOID IS A SMALL BOX LOCATED ON SIDE OF TRANS FACING FRONT OF VEHICLE..YOU MUST REMOVE TRANS COOLER LINE HOSES FROM FITTINGS ON TRANS..REMOVE INPUT SPEED SENSOR..UNPLUG PACK..8MM SCREW HOLDS IT..3 BOLTS HOLD PACK TO TRANS..YOU MUST CLEAN ALL GASKET RESIDUE THOROUGHLY BEFORE INSTALLING PACK..I'D RECOMMEND GETTING SOMEONE WHO HAS DONE THIS BEFORE IF YOU ARE NOT COMFORTABLE DOING THIS..I HOPE THIS HELPS
Posted on Dec 30, 2009
  • 23 Answers
SOURCE: 2007 Chevy Silverado when my check engine light
It's a safety feature. For example, if there is no oil pressure when you start the engine, you could not see that unless you were in the car and could spin a bearing or seize the engine by starting it remotely and letting it run unattended. So when the check engine light is on, there is something not working properly with the engine/engine management system and it wants you in the car where you can see the guages and turn the engine off immediately if there's a serious problem.
Posted on Jan 05, 2010
My 2009 Pontiac G5 started doing this about 3 months ago. On startup, the door locks make noise and it takes a while to shift out of park
Have the vehicle checked for DTC'S diagnostic trouble codes stored in the BCM - body control module . Everything is electroniclly controlled .
Automatic Transmission Shift Lock Control Description and Operation
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
• The automatic transmission shift lock solenoid (serviced as the automatic transmission shift lock actuator), as well as the body control module (BCM) and the engine control module (ECM). The shift lock solenoid is located within the floor shift control assembly with vehicles equipped with floor shift.
• The BCM controls the voltage to the shift lock control solenoid through the shift lock control solenoid controlled voltage circuit. The following conditions must be met before the BCM will remove voltage from the shift lock solenoid:
- The ignition is in the ON position.
- The engine control module (ECM) sends an input via GMLAN serial data to the BCM indicating the transmission is in the PARK position.
- The BCM determines the brake pedal is applied according the brake pedal position.
Since the shift lock control solenoid is permanently grounded, the BCM supplies voltage to the automatic transmission shift lock control solenoid, mechanically locking the shift lever in the PARK position as the solenoid energizes. When the brake pedal is applied, the BCM turns the control voltage output of the shift lock control solenoid OFF, de-energizing the shift lock control solenoid. The de-energized solenoid releases the mechanical lock allowing the driver to move the shift lever out of the PARK position. When the transmission is out of the PARK position, the shift lock control solenoid remains de-energized.
During remote start operation, the BCM will energize the shift lock control circuit, locking the shift lever in the PARK position.
The BCM supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position, the reference voltage is taken directly to ground and the BCM senses 0.0 volts on the signal circuit. If a door lock switch is placed in the unlock position, the reference voltage is taken to ground through a 15k ohm resister that is internal to the door lock switches and senses approximately 2.9 volts on the signal circuit. This is how the BCM determines what portion of the door lock switch was activated.
Aug 22, 2017 | Pontiac Cars & Trucks
Where is module on brake peddle for shifting out of park on cadilac srx4 2007
There is no module on the brake pedal . There is a brake switch , do the brake lights work ? If the brake lights work switch is ok .
• The body control module (BCM) controls the voltage supply circuit of the shift lock control solenoid. The following conditions must be before the BCM will supply voltage to the shift lock control solenoid.
The BCM controls the voltage to the shift lock control solenoid through the shift lock control solenoid controlled voltage circuit. The following conditions must be met before the BCM will supply voltage to the shift lock solenoid:
• The ignition is in the ON position.
• The engine control module (ECM) sends an input via GMLAN serial data to the BCM indicating the transmission is in the PARK position.
• The BCM determines the brake pedal is applied according the brake pedal position.
Since the shift lock control solenoid is permanently grounded, the BCM supplies voltage to the automatic transmission shift lock control solenoid, mechanically unlocking the shift lever allowing the driver to move the shift lever out of the PARK position as the solenoid energizes. When the brake pedal is not applied, the BCM turns the control voltage output of the shift lock control solenoid OFF, de-energizing the shift lock control solenoid. The de-energized solenoid mechanically locks the shift lever in the PARK position.
During remote start operation, the BCM will de-energize the shift lock control circuit, locking the shift lever in the PARK position.
Your best bet ,have it towed to a qualified repair shop !
Oct 15, 2016 | 2007 Cadillac SRX
I have an Astrostart hst5224, It will star then immediately shut off. My jeep is A manual transmission
[PDF]MODEL RSS-5225 - DirectedDealers.com
www.directeddealers.com/manuals/OG/Astrostart/RSS-5225_OG-Eng.pdf
Immediately report any malfunction to the AstroStart dealer that performed the ... Always turn off the main switch when not using the remote starter for .... The startmodule will inform you of the status of door locks, the alarm and of the engine. .... If the trunk is opened for more than 5 minutes, the system switches to the.
How do you reprogram an AstroStart remote HST5224
www.answers.com > Wiki Answers > Categories > Cars & Vehicles
In order to reprogram an AstroStart HST5224 remote, you must putthe key in the ignition ... lamp) b, press and hold UNLOCK button, after 1 second key LED will flash once c, .... C. Turn the ignition to ON (Do NOT Start) then back to OFF. ... B.Immediately after letting go of the lock and unlock buttons, press the lock button by ..
Nov 24, 2015 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Check Engine Light P0740. Car stalls when starting (occasionally), and the transmission slips when stopped.
This code is set when the transmission control module detects improper voltage at the torque converter clutch. This can be caused by low tranny fluid/dirty tranny fluid/defective torque converter clutch solenoid/electrical connections to from solenoid
Nov 09, 2015 | 2001 Infiniti QX4
Astrostart troubleshooting
Remote start devices rely on the vehicle being in a particular position or "state" before they will be able to engage the starter. Typical things checked is the gear shift position (park or neutral?), engine already running?, door locked? and more. If any one of these checks finds that it is in the wrong position or state, it will not engage the starter. Remember, even if the door is properly locked, or the transmission is in park, etc. one of the several switches that the remote start device checks may be damaged or faulty.
If you can't see something obviously wrong, you'll probably need to return to the installer to repair / adjustment.
Feb 20, 2014 | Vehicle Parts & Accessories
My Mahindra Scorpio is not starting when I am scanning my Car these fault code are coming P1647, P1832 please give the solution
Definition of check engine code P1647:
Chrysler/Dodge/Jeep:
Hydraulic Cooling Fan Control Circuit High
Daewoo:
OVER VOLTAGE
GM:
Driver 1 Line 7
Honda:
Power Command Signal Circuit Low Input,or Power Command Signal Circuit High Input,or Engine Torque Signal Circuit Low Input,or Engine Torque Signal Circuit High Input,or Mode Signal Circuit 1 Low Input
Jaguar:
Linear O2 Sensor Control Chip (Bank 2)
Kia:
Linear 02 Sensor Control Chip (Bank 2)
Volkswagen/Audi:
Please check coding of ECUs in Data Bus Powertrain
Volvo:
Ford:
LINEAR O2 SENSOR CONTROL CHIP (Bank 2)
Definition of check engine code P1832:
Citroen/Peugeot:
Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
Ford:
GM:
Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage
Lincoln:
Mercury:
Oldsmobile:
Sep 23, 2013 | Cars & Trucks
Astrostart won't start the car
You may need to reset the system.
SEQUENCE ACTIVATED BY THE PARKING BRAKE .
1. While engine is running (key in ignition switch), apply the brakes and hold the pedal down.
2. Move gearshift lever to neutral.
3. Apply the parking brake Once Twice
Note: The system can be set - at time of installation - to require that the parking brake be applied once or twice.
If set for two actuations, pause one second between the two.
4. Remove key from ignition (the system keeps the engine running).
5. Exit the vehicle.
6. Within 60 seconds, close all doors.
7. The system will stop the engine and blink the parking brakes once to confirm the sequence is valid (vehicle is
ready for a remote start command).
SEQUENCE ACTIVATED BY THE REMOTE CONTROL
3. Apply parking brake.
4. Send the start command (Model 801 & 2101 - Model 903 ).
5. Remove key from ignition (the system keeps the engine running).
6. Exit the vehicle.
7. Using the remote, send the STOP command. The system will stop the engine and parking lights will blink once
to confirm that the sequence is valid (vehicle is ready for a remote start command).
http://www.astrostart.com/Support/Guides.aspx
Nov 27, 2012 | Cars & Trucks
My car does not start or turn over. The radio works and so does the fan.
When you turn the ignition key to start your car, voltage from the battery flows through the ignition switch to the Park/Neutral safety switch and/or brake pedal or clutch pedal safety switch (you have to push the pedal down before the circuit will complete) to the starter relay or solenoid. When the relay or solenoid is energized by voltage from the ignition switch circuit, it closes a contact that routes more power from the battery directly to the starter to crank the engine. The starter motor spins, pushes the starter drive gear to engage the flywheel and cranks the engine.
Low battery (Check battery voltage, recharge if low, or jump start with another vehicle or battery charger).
Loose or corroded battery cables (Inspect, clean and tighten BOTH ends of BOTH battery cables).
Bad starter relay wiring connections or ground connection (Inspect, clean, tighten wiring connections).
Bad starter relay/solenoid (Check for voltage at relay, if relay has voltage but there is no "click" when key is turned to start, replace relay).
Bad starter (Jump battery voltage direct to starter to see if it spins, or remove starter and have it bench tested at auto parts store).
Damaged starter drive or teeth on flywheel (Remove starter and inspect drive gear and flywheel teeth, replace damaged parts if necessary).
Bad ignition switch (Check to see if voltage reaches starter relay/solenoid when turn to start. If not, check for open P/N switch and brake or clutch pedal switch. Replace ignition switch if defective).
Open P/N safety switch, or open Brake Pedal Safety Switch (automatic transmission) or open Clutch Pedal Switch (manual transmission). Bypass switch with jumper wire to see if engine cranks, or use test light or voltmeter to check for voltage passing through switch when ignition is turned to start.
Engine seized due to bearing failure or internal damage (Use socket and long handle to see if engine can be turned by hand, if not engine is locked up).
Engine hydrolocked due to coolant leak from leaky head gasket (Use socket and wrench to see if engine rotates, remove spark plugs and see if coolant comes out or engine can not be cranked with plugs out).
Jul 14, 2010 | 1995 Suzuki Sidekick
Engine will not turn over. lights, horn, everything else works, no clicks, no nothing, but it will not turn over.
You're describing a no rotation issue and not a no start issue correct? If you dont hear/feel the starter relay clicking, it eliminates everything in the circuit to that point meaning the ignition switch, Transmission Range Sensor (TRS) (you don't have a neutral start switch unless you have a rare manual transmission), ground input from the Powertrain Control Module (PCM) to the starter relay coil, and starter relay are good. Based on what you've said that leaves the primary battery cable from the battery to the starter, and the wire from the starter relay to the starter solenoid contact on the starter. Have you checked their continuity? One more voltage to check at contact 30 (input volts from battery to starter relay contacts) on the starter relay socket. Should see 12vdc all the time.
You should check the battery. The true test is a load test. Does jumping the battery using jumper cables make any difference? If it starts, change the battery. I take it to check the starter you jumpered the solenoid contact on the starter to the battery correct? Have you tried wiggling the battery cables as you turn the key? They can corrode and fail internally. Are the engine and chassy ground connections clean and tight?
Jul 14, 2010 | 2004 Dodge Caravan
Vehicle Parts & Accessories Logo
67 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
