Executone model mrk wiring diagram - Audio Players & Recorders
I have an executone model 36750-1, cannot find user guide. I would like to know how to use intercom for a single room?
how old is it
i cant find its user guide online either
is the company still in the business of selling phones ?
maybe the model is discontinued or no longer supported by them
all I saw was two used ones for sale online today
Mar 26, 2017 | Executone Lands Phones
How can I change the system main greeting on an Executone Model 64?
from any phone dial 436 and then press #, then enter managers mailbox usually 5000 and the password, by default it is 5000.
then 3, 8 and 1# for CCR 1,(or 2# for CCr2 and so on) and follow the prompts
if you need additional help, call me. 2033955027. Joe
Sep 05, 2014 | Executone 64 Corded Phone
How do I program the Executone model 64 LCD to
I assume you mean change the time and date and that depends on which system model you have....assuming you have an "IDS"...go to the receptionists phone ( the phone you reach by dialing 0 or 3001/ 301 ) and without lifting the handset dial 28 followed by the time in military format...if it worked you'll hear a few quick beeps after inputting the time. You might have an Executone Medley...if so > http://www.mainresource.com/PDFs/TipsMedleySysAdmin.pdf
If you have an older version of IDS you need to program it via a programming terminal or laptop. Leave your email here if you get this and I'll email you - can do it remotely via built in modem.
May 14, 2010 | Executone 64 Corded Phone
I need a wiring diagram for a patient station 3080203
Edge Conn-----Comm Cable----Lamp---- Ann/Ctl To Cab.
BRN Duty----------BRN
RED 24V+----------RED-------CPR
ORN IC Hot--------ORN
YEL 24V(-)-------YEL
GRN Ctl-----------------------------------TND
BLU Page----------BLU
VIO IC Gnd--------VIO
SLT Ann-----------------------------------CPR
WHT Care Lght---------------TND
Feb 23, 2010 | Executone Lands Phones
Need to know the color of feed wire
you need a haynes repair manual it has your wiring diagram.
Apr 25, 2009 | 1985 Lincoln Mark VII
Model 1B
you will need to have access to the phone system programming. you can do this through a laptop or through Operators programming if you have one there.
Once you are connected you will access A screen, then the EXT you need to program and then K for Keys. there is where you set up all of the programming on each key.
if you need more info, somehow contact me and I can help over the phone. Every system has a remote access through a modem that is built in on EVCM.card.
Aug 25, 2008 | Executone Corded Phone
Template showing what the keys represent is missing
all of the keys can be programmed with different key codes.
best thing you can do is press each one and see what it does. if you can get into programming of the phone system, then go to A screen and then that EXT, and K for Keys and you will see what is programmed on each key. You will see many codes, but if you put the cursor on each key you will see the description of each key abve key 2 and 3.
i hope this helps.
Jun 04, 2008 | Executone Corded Phone
EXECUTONE MODEL 64 Phone
quick way is to delete them both and re-record
Aug 08, 2007 | Executone 64 Corded Phone
 Grubhead
Grubhead
