Printers
Problem for Printers
Generic problem for all Printers
How do you fill empty
By bobbreakwell on May 07, 2009
how do you fill empty ink carteges
Solution #1
posted on May 07, 2009
Not Rated)
shamoo_101
Rank: Master
Rating: 82%, 12 votes
Hi, depends on the make of the cartridge but generally there are refill kits available for the more popular makes (HP Canon Epson etc).
The kit contains a syringe with a long needle that you push into the empty cart (normally in the top). This can be a messy job so best to put plenty of old newspaper down before you start.
You don't say where abouts you are but if you google "ink cartridge refill kits" you will find plenty of choice to buy online.
Hope this helps.
Was this helpful?
Yes
No
Solution #2
Not Rated)
johncarneys
Rank: Wiz
Rating: 76%, 104 votes
i use to have a refill, there not worth it real messy
Was this helpful?
Yes
No
Solution #3
Not Rated)
techniwiz
Rank: Wiz
Rating: 79%, 146 votes
if u want a working printer which would last for a long time ... do not refill a cartrige coz the kind of ink used in the refill and the ink used by the company are of different quality .,.. the ink in the original printer doesnt harm the head of the printer but the refill ink just makes a coat on the printer head and damages the printer head the original cartriges are no doubt expensive but ur printer is worth
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
MP 620 printer is it a good buy
Answer
konika minolta 1600 magicolor
Answer
toshiba es 282/283 series problem to get a print window office package (world excel etc) also... (More)
Answer
When switched on and it goes through its warmup routine before it abruptly stops and does not allow... (More)
Answer
6310 all in one printer won't print or scan but will fax and copy
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Printers:
Top Printer Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
