Question about Sceptre NAGA II X20WG 20 inch LCD Monitor
Brightness screen keeps popping up how do I make it stop?
When I bump, move or press any buttons on monitor brightness screen pops up I have to hold + button and press menu butoon twice to have meun pop up then turn off montior then back on to get it to go away
    New Friend:
  • 52 Answers
Sounds like the tactile switch is faulty. You know on a telly remote, you press the button to select the channel....well the switches on the monitor are the same. Behind the switch is a rubber contact which has a conductive contact which you must not clean( as such) it sounds like this is in permanent contact with the conductive elements inside it. As the switch is probably only 5mm x 5mm, it is a tricky DIY job to put a new tactile switch in, but easy for someone who does electronics.
Posted on Nov 24, 2013
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Apr 17, 2016 | Princeton Digital VL173 Monitor
Change brightness
The second button from the left on the bottom corner by the power button is the brightness button. If you press it the brightness menu is pop up on the screen. With the menu up you just use the three buttons on the left to select the function and the increase or decrease the brightness and contrast on the monitor.
BuddyMc
Aug 07, 2013 | Dell E178FP 17 inch LCD Monitor
Niko 1906W LCD Flatscreen/Widescreen monitor. - the brightness screen/bar keeps popping up every 5 seconds, and wont close. This is very annoying. Is there anything that can be done about this to make it...
It sounds like the button is probably stuck down or the contacts are too close. Try tapping the brightness button a few times, maybe with some force, and see if the contacts will snap back in place. This could also be caused if the monitor was in a severely moisture-rich environment.
Oct 28, 2010 | Niko 1906W LCD Monitor
A window saying Brightness is constantly popping up in the middle of the screen (very annoying :-Z) how can i get it to stop??????!?!
this monitor is triky.
try pressing brightness key and try playing with other keys EXCEPT PoWER button
this is only thing you may try.
THats it. bettter is to replace monitor
rate this solution and comment to get further assistance.
Sep 14, 2010 | Samsung SyncMaster 720N Monitor
Brightness indicator windows does not go away
Dear sir This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Have a Nice Day
Sep 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Brightness pop-up window on screen for a long long time
There are a few things that could be wrong; someone could have a remote and be messing you about, a button could be stuck on the monitor so its increasing, the computer could be slow or signals might be getting mixed up. try and figure it out based on what ive said. good-luck!
May 20, 2009 | ViewSonic E70fb 17" CRT Monitor
The setting is programmed into the memory of the monitor. It has been set that way, sort of like a memory button for your car's driver seat. The car remembers your favorite seat position, and the monitor is remembering your favorite brightness settings.
It's been a while since I played with any settings on a CRT monitor, but I'm sure if you give it a few minutes, you will find in the menu how to set up the memory recall feature on your monitor.
good luck.
tony
Dell Ultrasharp 21' monitor
I had the same issue. I pressed and hold the + button and the monitor did an auto adjust and the pop up stopped.
Aug 23, 2006 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Sceptre NAGA II X20WG 20 inch LCD Monitor Logo
66 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
