Question about Hilti PD42 Laser Distance Meter 0.05m200m
How to replace battery of hilti pd42 - Hilti PD42 Laser Distance Meter 0.05m200m
SCHEMATIC DIAGRAMS FOR HANTAREX PD42 plasma
Go to the manufacturer website and got to support or contact us requesting the info you seek!
Jan 16, 2015 | Televison & Video
Why does E107 comes up on my hilti PD4 screen and how can I fix
I had same problem on PD42 but code was E112. It normally comes after 3 seconds of switching on and by carrying out following steps it works.
Switch ON and start pressing plus button repeatedly and if battery symbol comes in left corner its working. Actually its 3 seconds when you need to press plus button when it beeps and error message comes on, but its much easier to keep pressing and try your luck. This is not permanent fix but will work every time you want to use it.
Sep 16, 2014 | Camping, Backpacking & Hiking
Where can i get a schematic drawing for a TE 5A battery charger
There are no schematics for the 5A charger. Those were not serviced by Hilti. If they were bad then they just replaced the whole unit. If your charger has no power at all there is a fuse inside that you can replace. Other than the cord that is about it. I think you can still get a charger from Hilti. 1-800-879-8000
Nov 22, 2011 | Hilti Drills
Hi Where can I get hilti battery packs re-packed or replaced at a reasonable price. Peter
If you are in the states I know that Batterys Plus will rebuild battery packs. They have rebuilt older Hilti packs for me. They have locations in most states.
Jun 11, 2011 | Hilti Drills
Hilti c7/36 I am looking for a electronic diagram
if the light on the charger are functioning ok. the problem is most probly the batterys. they dont last forever, replace the batteries and you should be ok.
Jul 20, 2010 | Hilti 285359 SF 121-A 2.0 NICD Cordless...
Hilti te2-a both battery's won't charge i haven't used it for a while but it is under 2 years old
IF you live in the US you can send it into Hilti tool repair and let them evaluate your batteries. Or you can take it to any Hilti Center to be checked out. You can call1-800-879-8000 to locate the nearest Hilti Center to you or arrange to send into tool repair.
Jul 15, 2010 | Hilti Drills
Hilti PD42 Laser Distance Meter 0.05m200m Logo
674 people viewed this question
Top Hilti Measuring Tools & Sensors Experts
Tom Chichester
Reprep
Are you a Hilti Measuring Tool and Sensor Expert? Answer questions, earn points and help others
