Sharp ar m155 showing add paper when there are papers in the tray and also failed to pick paper for copying.
    Habit-Forming:
  • 190 Answers
Paper sensor detector faulty or broken.
Posted on Dec 25, 2013
Benimur
  • 6966 Answers
SOURCE: printer all in one sharp ar-m155
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
Posted on May 03, 2008
Bubbabear64
  • 2794 Answers
SOURCE: can not copy from tray/drawer, but get copy from multi-bypass tray
You still have to scan the document before you copy it. I'm just trying to determine if something is going on with the automatic document feeder when you the images are being scanned.
It could be that the feed tires aren't picking up the paper but usually the jam light goes on if it cant pick them up.
One idea could be to reduce the amount of paper in the tray. Sometimes if it too full it can do this.
If that doesn't work, it should have a technician look at it to see what is causing the feed tires not to pick up the paper.
Posted on Jun 26, 2008
POCBM
  • 121 Answers
SOURCE: paper feed
Check tray 1 there should be an arm hanging down in the center of the tray the arm goes thru a slot in the metal plate. This arm moves when you install paper in tray 1. If the arm is missing or not in the slot the machine will think paper is in tray 1 and try to feed from tray 1. You can try changing the paper size setting for tray one to something other than the size in tray 2.
For example If tray 2 is set for 8.5x11 set tray 1 for legal.
The machine should then pull the correct size based on the print job.
Hope this helps
Posted on Mar 04, 2009
Sharp Tech
  • 63 Answers
SOURCE: Problems with SPF message and black copies
The "Check SPF/RSPF" issue can be a couple of things
  1. If the scanner only moves from right to left then immediately moves back then the copier needs to be adjusted.
  2. If the scanner moves from right to left and tries to feed then displays message then the ADF needs to be cleaned.
Same for the dark issues
  1. If you lighten the exposure and the copies come out better then copier needs to be adjusted
  2. If you lighten the exposure and the copies come out the same then you may have a few problems check the following;
  • Open right side door and look at drum green/blue cylinder . If it is covered with toner (black film) then you might have a drum short.
  • Open right side door and look at drum, if it is not covered then you may have a board issue.
While making a copy off the glass listen to the right side of the copier and if you can hear a screeching sound then you could be having an electrical short that is causing your black copies.
Depending on your findings depends on the remedies.
Posted on Oct 17, 2009
  • 34 Answers
SOURCE: Copier Sharp AR-M237 a Misfeed Occurred message
First try a different tray to see if it works, if it does than the paper tray you are using may have dirty feed tires or look for something obstructing it.
Posted on Mar 24, 2010
Testimonial: "Thank you so much for the help , I have tried the Bypass Tray but still getting the jam code."
It will not copy, the screen shows a P and it smells like it's running hot. What is the problem?
When this copier can not find paper by pass tray or casset then show it p .P mean add paper.Before you select paper tray then make a copy.Thanks
Tareq Bin Mostaq
Bangladesh.
Aug 13, 2011 | Sharp AR-5316 Advanced Digital Imager...
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
My sharp ar122en copier cannot load paper, please
Does loading mean picking papers? If so remove the paper tray and rotate the semi-circular rubbers . Clean them with a clean damp cloth and return the tray loaded with papers.
May 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
My copier AR-M208 won't pick up paper from tray 2 It starts too then nope it says its jamed but not really, we open side door and tray close both then it will copy one or two pages the stop again
It may be that either the feed rollers in that drawer are dirty or worn out and need replacement. You might also want to ensure that there is no dogeared paper in that drawer. Meaning that the edges of the stack are all nice and even, no corners bent over.
Jun 29, 2009 | Sharp AR-M208N Copier
Incomplete copy
the paper is set to 8.5-11 and you are running letter r paper u must set the copier tray to the proper size
Mar 03, 2009 | Sharp AR 201 Copier
I can't use Print function for ByPass or Document Feeder?
The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
Feb 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Adf misfeed ar-m237
Try cleaning the pick rollers with alcohol or clean cloth dampened with water.
Feb 10, 2009 | Sharp AR-M237 Copier
Wrinkled paper
Many possibilities can cause this....
The Pick Up Rollers could be worn out and not picking the paper up correctly.
Something blocking, or catching in the paper path
The Fuser unit rollers could be sticking, going bad..
The Exit Delivery could be warped, cracked.
After these machines get old, the heat from Fuser unit causes the delivery Exit to melt, warp, and become extremely brittle.
The simple things you can check your self:
Entirely remove the paper tray, look in the copier where the paper tray slides in, look in side the machine where the paper tray goes, make certain there is nothing in the trays path.
Take the paper out of the paper tray, go through the paper make certain there is no crumbled paper in the tray, it should lay flat and even in the tray...
My favorite, check the paper it self.
I once was at a customer whom recently changed their paper supplier; every 10th piece of paper was creased from the new **** of paper. I found that the entire Box of paper had creases in every ****. It was the paper not the machine. It was pre-wrinkled.
Feb 06, 2009 | Sharp AR-207 Copier
No paper alarm
Check cable connectors. Or check if the tray rises after it gets inside the copier, maybe you must stretch the springs.
Oct 12, 2008 | Office Equipment & Supplies
REPLACING THE TONER
HI! I HAVE BOUGHT THE SHARP PRINTER/COPIER/FAX/SCAN MODEL AR-M155, WHEN I INSERTED THE NEW TONNER AND MAKE THE PHOTOCOPY TESTING I GOT THE OUTPUT COPY WHICH SHOWS THE HALFED COPY IN VERTICAL ON RIGHT HAND SIDE WHEN YOU READ THAT PAPER SO WHAT COULD BE THE PROBLEM ON IT WHILE IT IS NEW MACHINE???? AM SCARED!!!. PLEASE IWOULD BE VERY HAPPY IF YOU HELP ME TO SOLVE THIS MY REQUEST PROBLEM.
THANKS,
Aggrey34
Sep 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
jasbo
jasbo
