Question about LG Keys-U-See Keyboard
KEYS U SEE DRIVERS
PROBLEM STILL REMAINS TH KEYBOARD AND MOUSE ARE IN USE WITH A ASUS MINI PC NOT A LAPTOP AGAIN THANKS FOR ANY HELP
    New Friend:
Wrong keyboard
Posted on Nov 24, 2013
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
Reattach keyboard key
If the tiny plastic hinges are still attached to the keyboard then place th W key over these hinges align it with the other keys and press down on the W key until it clicks onto these hinges.
Jan 09, 2013 | ASUS K73SV-DH51 Laptop
My mouse locked how do i unlock it
there is a button on some of the asus laptops that shut off the onboard mouse. check for that key also look on your F1-f12 keys for a mouse logo if so hold down the FN key and hit that F10 or w/e number key and it should turn it back on let me know
Mar 19, 2011 | ASUS Laptop Keyboard for Asus Eee PC
Some keys on ASUS Eee PC 1000H PC Notebook keyboard not working. I replaced the keyboard with original new but again the same keys does not work.
MAY BE THE PART WHERE U CONNECT THE KEYBOARD ARE BAD, TRY PRES THE KEYBOARD CONNECTOR AND TRY THE KEYS SOLUTION HEAT GUN TO DO IT YOUR SELF BUT I RECOMMENDED A REPAIR SHOP
Nov 23, 2010 | ASUS Eee PC 1000H Laptop
My asus mouse freezes, gets stuck and wont move
my touch pad mouse on my asus laptop will only work in safe mode, help
Jul 13, 2010 | ASUS (W2JBY007MDVDRW) Notebook
The keyboard has suddenly got limited function
I have the same problem with an Asus Eeepc 900HA. I am trying to solve, if you solve firts write to me to jhonald@redesfx.com, thanks
Jul 11, 2009 | ASUS Laptop Keyboard for Asus Eee PC
Sony laptop cannot use keys on the laptop seems to have frozen
It could be a software or hardware issue.
Check Sony's website for updated keyboard / touchpad drivers.
If that doesn't work, uninstall the keyboard from the device manager and reboot the computer.
If that doesn't work then it's likely a hardware issue.
Jun 13, 2009 | Computers & Internet
Hi i just bought a new motherboard(asus p5kpl-am) and installed it, the problem is that it works fine but my screen just remains blank and my mouse and keyboard arent working. when i put my older...
remove any printers or external hard driver and jsut have the mouse and keyboard plugged it. Wait until you get the first boot down and the drivers are installed. If that doesnt work you purchased something thats not compatible with that mainboard
Jan 15, 2009 | ASUS K8V-MX Motherboard
Keyboard problem - asus
it seems to me that you have the NumLk activated, deactivate it by pressing Fn + NumLk, hope this works!
Nov 01, 2008 | ASUS Eee 4G Notebook
LG Keys-U-See  Keyboard Logo
121 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
