Question about Dell 2200MP Multimedia Projector
Dark Area Growing on Right Side of Image
My Dell is 4 years old and the color wheel was replaced a year ago along with some other component circuit a year ago. The projector is used daily. 4 months ago all images started showing a darker area on the left side (project upside down/ceiling mount) that is growing towards the right of the image. It started as barely noticeable on the left and now it is covering 1/3rd of the image. I was told at a local electronics retailer this was likely the bulb, so I replaced the bulb and it had no effect. The only thing I can guess is this is some lens that is darkening from the heat the more it's used. Any help would be appreciated.
  • 1_tony Jul 28, 2008
    Have the same problem with the shade growing. Anyone one have a service manual so that I can take the unit apart and attempt to correct the shifting lens? How does one fix the position of the lens?
    jekyllhyd at yahoo dot com
It isnt the lens. There is a crystal asembly that the light is reflected thru after it hits the color wheel. It is 4 pieces of completely mirrored glass glued into a small metal holder. One of those pieces has shifted. To fix it, you can take it out and possibly have a jeweler repair it. It is difficult to take out, but it is doable. Feel free to contact me if you need to. email is (bill @ baerwalde . com) Just remove the spaces.
Posted on Nov 09, 2007
VIZIO 42in LCD HDTV - Dark colors and flickering
It sounds that the back-light CCFL lamp is faulty. It is time to replace it. When replacing, do it to all CCFLs, because, the life time to these lams are expiring now, as the set is nearly 4 years old. Check this link to get more details about how to replace the CCFLs. Pull up older posts there. Some among it have details.
May 29, 2013 | Vizio 42 in. LCD TV
Blue shadowing on our 7 year old Sony Grand Wega KDF-60XBR950
Aug 24, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
DLP Image
In some cases,after installing a new color wheel, the speed of the wheel motor must be adjusted to obtain proper speed to ensure a satisfactory image. Unfortunately, you can not and should not attempt to do this adjustment yourself as the service menu contains many adjustments which if accidentily mis-adjusted may cause irrepairable harm to your TV. Ask a local samsung servicer to do an "index delay" adjustment in the service menu.
Jan 19, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsug rear projection tv, everything looks green
Dust accumulation in color wheel, light tunnel, chip area can cause green tint.
It is very delicate area, light tunnel and chip can be easily damaged. Remove light engine assembly and color wheel. Blow dust out. Re-assemble. If the gasket around the color wheel housing is not replaced in the right position, or the housing screws not tightened correctly dust will contaminate the color wheel/light tunnel area.
Call someone that has done it a few times. If near Calgary, call me.
Jul 14, 2008 | Samsung HCM4216W 42" Rear Projection...
DLP Image
I heard people say they adjust the speed of the color wheel and also the blub will cause the same problem. i don't know where the adjustment is located.
Feb 03, 2008 | Televison & Video
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Picture deterioration
Your whole problem my freind is dryed up capacitors. You should go, if you have the technical ability to replace these capacitors, to, download the schematic diagram, and start replacing the waveshaper capacitors in the vertical drive circuit.
Sep 23, 2006 | Sony KV-35V35 TV
not sure but you could have a bad color wheel i would suggest a service call from your local shop
Jun 07, 2006 | Samsung DLP HL-P5663W 56" TV
My monitor changes colors
CRT monitors can last way past 4 years if taken care of. Please give more detail of your problem since there's not much we can tell by your description. What colors? what was the progression of the problem? can you attach a screen shot? Please comment back
Jun 02, 2006 | Dell E551c (Dark Gray) 15 in.CRT...
Dell 2200MP Multimedia Projector Logo
209 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
