Question about Jenn-Air Ovens
Error code SAb bath on Jenn Air oven. Held clock button down for 5 seconds and key pad still will not work.
  • 5 Answers
Possible need new key pad.first check no loose connection from key pad to the control board,if not replace key pad
Posted on Nov 24, 2013
  • 76 Answers
SOURCE: Burners & clock are working, but oven, brioler & self-cleaner won't. Error F-0, EO
Brandyz Most likely the problem with your range is the spark module. It is located in the control panel on the right hand side. You can access it by removing the back panel held with four screws from the back. Remember to unplug the range first. The name plate with the model number and the serial number is on the frame behind the storage drawer. You can buy the spark module here: http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.545301030&type=10&subid= It comes with installation instructions. Gendos...post back
Posted on Jan 30, 2007
  • 1314 Answers
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
Posted on Feb 19, 2008
  • 72 Answers
SOURCE: Maytag single electric built in with a display saying sab bath
It is in Sabbath mode, used for Jewish holidays. Anyway, hold the cancel button for 3-5 seconds and it should revert back to normal operating mode. It will still bake in Sabbath mode but will not display anything due to the laws regarding observation of the Sabbath
Posted on Jun 16, 2009
jumptrout51
  • 3361 Answers
SOURCE: My oven will not move from SAb o 5A6 and buttons
You have inadvertently entered the Sabbath Mode.
Try holding the clock button for 5 seconds to clear it out.
Posted on Dec 12, 2009
Testimonial: "Thank you so much!!!! Thought I would have to pay for a repair call. Merry Chirstimas - you helped me save for Christmas."
taran_2005
  • 10515 Answers
SOURCE: Jenn-air electric double control does not work - clock is on
Disconnect the Power Supply for few minutes, say 30 minutes and then Turn the Oven ON.
Do you see any Error Message?
How old the Unit is?
Do you have any Experience to Fix this?
Do you have all the tools?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
Jenn air expressions double oven
F-7 error code means that the Function Key is stuck or shorted out. You will have to replace the touch pad or if the touch pad is part of the clock, you will have to replace the clock (ERC).
Aug 18, 2014 | Jenn-Air Ovens
Sabbath mode on display. oven not working
Press and hold 'clock' pad, under keypad, for five seconds. 'sab' should blink for a few seconds and then clear.
lp
Dec 30, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I have a jen air propane oven and four stove burner and it is flashing a the code f7-1 and saying call a a tech. Please help the beeping is very annoying
Hi, the error code implies that the Function key shorted or stuck..
You need to replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 20, 2010 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air gas wall oven some how got stuck in ''Sabbath'' mode and unable to reset.
ok it happens / so to enable the Sabbath mode 1 open the door. 2 press cancel/off. 3 press the number pads 7&8 and 9 , in that order. 4 press Number pad 6 . 5 press start. "sab and on" will appear on the display ..( now to disable the sabbath mode .}. ( repeat the steps above to disable the Sabbath mode. " Sab and off" will appear on the display .. there now that wasn't too tuff was it .. mm hope this helped ..
Jul 15, 2010 | Jenn-Air Ovens
What does F- mean on my jenn air expressions electric wall oven? If it means what I think, then this is the 4th failure in 10 years. This just can't be right!
Common fault codes:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 22, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Dec 12, 2009 | Jenn-Air JJW7530DDS Electric Single Oven
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
Ovens Logo
113 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
