Question about Dryers
Whirlpool dryer no heat
Stalker washer dryer model ylte6234dq2 no heat
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Be sure you have 220v to dryer everything will run on 110v except the heater
Posted on Nov 25, 2013
  • 43 Answers
SOURCE: whirlpool dryer
First make sure you have power to the unit through the plug. If power is present, then you most likely have an open Thermal Safety Fuse. The Thermal is a Safety feature that shuts off the power to the Heat Element in the event the Blower is not blowing or the Lint Vent becomes clogged not allowing air to flow over the Heat Element. NO air flow, Heat Element over heats, Thermal Safety Fuse opens, power shuts off. If the Thermal Safety Fuse is open find out why. Was the blower not working? Was the Lint Filter clogged? ( Lint Filter should be cleaned after each use to assure continued air flow.) Was Lint Vent Clogged? This is the Vent Hose that goes from the Dryer to the outside of your house. It should be checked for free air movement. The next thing-- Could be a defective Timer or Control Module.
Find where you lost power and WHY!!
Posted on Jan 27, 2008
michiganfan9
  • 179 Answers
SOURCE: No heat Whirlpool dryer
when you turn on the dryer does the ignitor glow if it does replace the coils if not check the thermal fuse
Posted on Dec 20, 2008
  • 1122 Answers
SOURCE: Whirlpool dryer heat not working
DO YOU HAVE A METER? FIRST CHECK THE DOOR SWITCH,SECOND REMOVE THE BACK PANEL AND CHECK ALL FUSES AND THE HEATING ELEMENT,LET ME KNOW WHAT YOU FIND AND WE CAN GO FROM THERE-MIKE
Posted on Feb 26, 2009
protek480
  • 1714 Answers
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Posted on Jul 12, 2009
  • 415 Answers
SOURCE: whirlpool dryer model LGR6611LQ0 will not heat up
check for tripped breaker and proper voltage, next check to see if turns on if your getting air to the outside vent if ok the you need to open the unit up (unplug it FIRST) your be looking for the thermal fuse and or the cutoffs these will be attached to the blower housing assy ohm them out and also if electrical one check the heating element as well most cases this will solve your problems
Posted on Aug 21, 2009
Hi my whirlpool doesent speen
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will notturn - 11068202794. ApplianceVideo.com ...
Kenmore / Whirlpool Washer Not Spinning 1 - YouTube
? 11:33
https://www.youtube.com/watch?v=TB_W6sPdzkM
Jul 10, 2012 - Uploaded by Bill Newberry
Kenmore / Whirlpool Washer Not Spinning 1. Bill Newberry ... Washer will not spin the clothes dry ... Now ..
Dec 03, 2015 | Whirlpool Dryers
How to shut off dryer end of cycle beep. Can u run
If the model number is correct, the dryer End of Cycle signal cannot be adjusted or turned off. The informatrion is listed on page 11 of the Owner's Manual:
http://www.managemylife.com/mmh/owner_manuals/16695/WHIRLPOOL-Laundry-Centers-L0710382?brand_name_search=LTE5243D
The only way to turn the signal off, is to remove the operator console, locate the signal (buzzer) module and disconnect the wire(s). The buzzer is listed as item 32 under the "Washer/Dryer Control Panel" parts listing:
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-YLTE5243DQ2/1198/0152000/W0702346/00001?blt=06&prst=&shdMod=
CAUTION: If you choose this option, make sure you UNPLUG the washer/dryer before servicing anything inside. If you disconnect any wires, make sure you cover them with heat shrink or electrical tape to keep them from coming into contact with anything else.
The washer and dryer use a common power source, but the rest of the functions operate independently of each other. You can safely run both units at the same time.
If need further assistance, please let me know. I hope this helps you.
Aug 09, 2011 | Whirlpool LTE5243D Top Load Stacked...
Its about my washer/dryer combo whirlpool model lte6234dqs: -the dryer don't produce hot air and therefore don't dry. -Anybody please?
check your breaker to the appliance you must have 220 volts before it will heat if you only have 110 volts it will run but not heat otherwise it could be a thermostat or heating element which is hard to say with out me being there to check it out with a meter
Nov 19, 2010 | Whirlpool LTE5243D Top Load Stacked...
I have a stackable washer/dryer whirlpool model #WET3300SQ1. Heating element in dryer is not heating. We have replaced the heating element and it is still not working.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin YLTE6234DQ2 washer is leaking water from the bottom. I need to remove the front panel to see what the problem is but can't seem to get it off. I have looked at suggestions to push in...
have you looked near the bottom of the front panel near the floor,there are 2 or 3 screws located at a 45 degree upward angle(to hide them from view) so they dont show,remove these and the front should hinge upward like an auto hood and the clips near the top should let go when its raised far enough upward
Apr 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
No heat in our Whirlpool Dryer Model LTE5243DQ3. Tested both fuses and all the wires have power. Still there is no heat. The parts tested were 3398128 and 3404154. Are we missing somthing?
There is what's called a high limit in dryers. It protects the unit in case of over heating. It usually is small, has 2 wires connected to it. Check continuity. Or' check your heating element for breakage, or continuity.
Dec 23, 2009 | Whirlpool LTE5243D Top Load Stacked...
YLTE6234DQ2 - Dryer not heating up
Where is NA? Have you tried some websites for part resources? I found your part available at partstore.com. If you type in your model number, I found your element on page 15 as part #3387749. It lists for about $60. I hope this gives you a little more hope.
Jul 08, 2008 | Whirlpool LTE6234D Top Load Stacked...
Dryers Logo
63 people viewed this question
Top Dryers Experts
