Question about Galaxy 5 cu. ft. / 142 liter Chest Freezer 13500
Galaxy freezer doesnt cool
Galaxy chest freezer will not get cold
Magic Chef HMCF7WI is the green light suppose to go off ?
I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
May 17, 2014 | Magic Chef 7 cu. ft. / 198 liter Chest...
Magic Chef #HMCF7W1 should the green light go off?
same as last post... I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
My ignis chest freezer isn't freezing anymore even
your cooling system matchine facced this problem.
Mar 20, 2013 | Freezers
Brand new freezer. power light is on. run light is on. I can clearly hear the compresor running. does not cool at all. ??? help
Chest freezers produce cold very slowly, so it could be an hour or more before you start to feel the cold. If still no cold, ( and I mean absolutley no cold) then you most likely have adamaged refrigerant line and the (freon) refrigerant has been lost. Take it back, or call for warranty repair.
Nov 27, 2010 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
Doesnt get cold
It may be just coincidental but it may need a recharge; most cooling systems eventually leak and if it has been standing in a hot area, this may have accelerated the loss.
Get an estimate before having anyone come since the cost may be higher than the freezer's current value.
May 15, 2010 | General Electric Chest Freezer FCM5SU
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
After being unplugged for one year, my Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A turns on, but does not get cold. What is the problem?
It's probable that you've lost refrigerant in the cooling system. Unfortunately, leaks in those systems can be hard to find so check your warranty to see if the labor is still covered.
Oct 26, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Chest freezer repair
I had the same problem with an upright and so I bought a piercing valve and charged the compressor with 134R and has been working great since.
Jul 05, 2009 | Freezers
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Galaxy 5 cu. ft. / 142 liter Chest Freezer 13500 Logo
29 people viewed this question
Top Galaxy Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Galaxy Freezer Expert? Answer questions, earn points and help others
